Strange problem when saving file 13.5.2 (Solved. Not a bug)
davoodice2
Post by davoodice2 »
hi.
some times when I save File it doesn't save !!!
actually it saves but not in my file . it saves with a strange name in other file !
please see the video.
save with these names
SOLVED!
I forgot to close first file :D . But why did it work before?! :? :shock:
davoodice2
Re: Strange bug when saving file 13.5.2
now I known this is not a bug.
it happens after run this script.
function DV_Incremental_Save:Run(moho)
local path = moho.document:Path()
if (path == "") then
    local alert =  LM.GUI.Alert(LM.GUI.ALERT_WARNING,
                MOHO.Localize("/Scripts/tool/SaveIncrement/FirstSave=Please save your file"),
                nil,
                nil,
                MOHO.Localize("/Scripts/OK=OK"),
                MOHO.Localize("/Scripts/CANCEL=CANCEL"),
                nil)
            if alert == 1 then
                do return end
            end
    moho.FileSave()
else
   local OS1 = package.config:sub(1,1)
    if OS1 ~= "/" then
     OS1 = "\\"
     end
   local name = moho.document:Name()
   local file = io.open(path, "rb")
   local source_content = file:read("*all")
   local version_number = 1
   local file_name_part = string.gsub(name,".moho", "")
   local dir_part = string.gsub(path,name, "")
   local backup_folder = dir_part..file_name_part.. [[ Incremental Saves]] ..OS1
  os.execute( "mkdir ".. '"' .. backup_folder .. '"' )
  local path = backup_folder
    moho:BeginFileListing(path)
	local fileName = moho:GetNextFile()
    while fileName ~= nil do
		sepPos = string.find(fileName, ".", 1, true)
		if (sepPos ~= nil) then
			local extn = string.sub(fileName, sepPos + 1)
			if (extn == "moho") then
                local corr = string.find(fileName, "_%d+.moho")
                if (corr ~= nil) then
                        local current = tonumber(string.match(string.match(fileName, "_%d+.moho"), "%d+"))
                        if( current >= version_number) then
                            version_number = current+1
                        end
                end
            end
        end
    end
local new = file_name_part .. '_'..version_number..'.moho'
file = io.open(path..new, "wb")
file:write(source_content)
file:close(path..name)
moho:FileSave()
moho:Click()
end
end
I think it happens because of file:Close() problem
any help please?
Re: Strange bug when saving file 13.5.2 (Solved. Not a bug)
To make the saving process safer and avoid the 0k files' issue sometimes appeared, when you save, 13.5.2 saves a copy of the file first. Once that saving is complete, Moho replaces the old file with the new one.
This process is normally extremely quick, but it can vary depending on how heavy the file is.
We made this change to be sure that if anything goes wrong with the software or the computer while saving, users won't lose their files.
Why does file:close have an argument? You only need an argument when using the syntax io.close(path).
And why are you writing the content of the file, instead of just saving it to a new name?
davoodice2
Víctor Paredes wrote: ↑Wed Nov 10, 2021 2:55 pm To make the saving process safer and avoid the 0k files' issue sometimes appeared, when you save, 13.5.2 saves a copy of the file first. Once that saving is complete, Moho replaces the old file with the new one.
very intelligent improve I see that in maya too. even when rendering it create a copy of file and renders that for prevent changing scene during render.
davoodice2
synthsin75 wrote: ↑Wed Nov 10, 2021 4:44 pm Why does file:close have an argument? You only need an argument when using the syntax io.close(path).
just my mistake .
synthsin75 wrote: ↑Wed Nov 10, 2021 4:44 pm And why are you writing the content of the file, instead of just saving it to a new name?
because I want to store a copy of file before current saving. its easy if just save with increment name in current folder. but when i want to save backups in another folder it's become tricky. i have to copy my file before saving changes and working file name must stay same as before.
davoodice2
hi victor.
Based on the problem that has arisen now, I have three suggestions:
First, the small icon next to the document name tab will not disappear until the file is saved successfully.
And secondly, if there is a problem for saving file for any reason, the moho give us a message.
And third, FileSave() function have a returned value for checking successful save.
davoodice2 wrote: ↑Wed Nov 10, 2021 11:59 pm
ScriptInterface:FileSaveAs(path) can save with the same file name to a different location, defined in the path.
And you can reopen the original file using ScriptInterface:FileOpen(path).
davoodice2
synthsin75 wrote: ↑Thu Nov 11, 2021 8:42 am
please Notice: We must store file before any changes we made. FileSaveAs or save cant do these
davoodice2 wrote: ↑Thu Nov 11, 2021 10:24 am please Notice: We must store file before any changes we made. FileSaveAs or save cant do these
Sure they can, if you use them before any changes. Just like copying and writing the data before changes.
davoodice2
synthsin75 wrote: ↑Thu Nov 11, 2021 11:06 am
Wes! I speak about incremental save! :?
davoodice2 wrote: ↑Thu Nov 11, 2021 12:15 pm
synthsin75 wrote: ↑Thu Nov 11, 2021 11:06 am Sure they can, if you use them before any changes. Just like copying and writing the data before changes.
I am too. :D
