add layers to layer comp
davoodice2
Post by davoodice2 »
hi
I create layer comp and add group layer. but when expose, just groups show. and sub layers will be hide.
how to create layer comp that store current state of layers?
and how to fix group problem?
thanks.
	local doc = moho.document
	local comp = doc:AddLayerCompWithName('DV_solo')
	comp:SetAutoAddsGroupLayerChildren(true)
	comp:AutoAddChildLayers(doc)
	comp:AddLayer(MasterLayer)
Re: add layers to layer comp
Off hand, it looks like you need to pass NULL to AutoAddChildLayers, as per: https://mohoscripting.com/methods/1273
davoodice2
synthsin75 wrote: Tue Nov 02, 2021 6:08 pm Off hand, it looks like you need to pass NULL to AutoAddChildLayers, as per: https://mohoscripting.com/methods/1273
I did before. default value is NULL too. but I still have problem
	comp:SetAutoAddsGroupLayerChildren(true,NULL)
davoodice2 wrote: Tue Nov 02, 2021 11:34 pm I did before. default value is NULL too. but I still have problem
I said to pass NULL to AutoAddChildLayers, not SetAutoAddsGroupLayerChildren.
davoodice2
synthsin75 wrote: Tue Nov 02, 2021 11:45 pm
lol. sorry .
	moho.document:PrepUndo(true)
	local curLayer = moho.layer
	comp:AutoAddChildLayers(doc,NULL)
again when I use expose to layer comp in moho , all layers will be off
davoodice2
this is all code.
do I write some thing else?
maybe should i used 'MohoDoc:AddLayerComp(comp)' ?!! but what is this command? how to pass comp?
davoodice2
	local dsfd = comp:AutoAddChildLayers(doc,NULL)
	print(tostring(dsfd))
print returns false
davoodice2
	local dsfd = comp:AutoAddChildLayers(doc,curLayer:Parent())
I frustrated. I can pass every thing for arguments .no error. Just do Nothing. why doc should be one of args? do I access to other docs ?
You aren't adding any layers to the comp. So there's no group to have its child layers added.
davoodice2
synthsin75 wrote: Wed Nov 03, 2021 10:04 am You aren't adding any layers to the comp. So there's no group to have its child layers added.
I added group. But again dont work. No child added
	comp:AddLayer(doc:Layer(0))
	comp:AutoAddChildLayers(doc, NULL)
SetAutoAddsGroupLayerChildren sets what is allowed for that comp, as per: https://mohoscripting.com/methods/1272
Then AutoAddChildLayers adds child layers only if SetAutoAddsGroupLayerChildren allows it, as per: https://mohoscripting.com/methods/1273
So comp:SetAutoAddsGroupLayerChildren(false) will not allow comp:AutoAddChildLayers(doc, NULL) to add children, but comp:SetAutoAddsGroupLayerChildren(true) will.
