scripts duplicated in the tools panel
I didn't post this on the bugs section because I feel I may be doing something silly wrong. Since a few weeks ago I have some script tools duplicated in my tool panel, always in pairs one with the correct provided icon and the other with no icon just a question mark.
What did I do wrong? They are on the tool folder and the files are not duplicated only one lua and one icon for each script. I tried removing them (and both got removed from the tool panel) and installing them again but they keep appearing like that in pairs. It only happens to 3 or 4 script tools but not to the rest.
Lukas
Re: scripts duplicated in the tools panel
Post by Lukas »
Your tools_list.txt file might be incorrect. Check speling mistakes and make sure even the capital letters match the scripts.
Lukas wrote: Thu Oct 07, 2021 2:21 pm Your tools_list.txt file might be incorrect. Check speling mistakes and make sure even the capital letters match the scripts.
Yep it might because I didn't know it existed. I probably copied it from someone's archives some day.
Thanks I will look for errors there. And now that I'm trying to resolve this, I always wanted to know how people make sections inside the tool panel and also how can I create sections (folders?) on the scripts menu. Is there something about that in the documentation? Or is there any tutorial about that?
Daxel wrote: Thu Oct 07, 2021 2:28 pm ...I always wanted to know how people make sections inside the tool panel and also how can I create sections (folders?) on the scripts menu. Is there something about that in the documentation? Or is there any tutorial about that?
Edit / Preferences / Tool Layout
page 443 in the 13.5 manual
Tools can also have different file names but their internal function names are the same. These will show up as two tools, one with an icon and one without, but both will be using the same script (the last one Moho happened to load). This can happen with some custom scripts, where the file is not named with lm_ but the internal code is, to utilize some functionality that's only available to LM named functions.
hayasidist wrote: Fri Oct 08, 2021 1:14 am
Oh cool thank you!
I think I copied that file installing scripts from Mynd. I wasn't sure if I had to do that. I deleted it today expecting Moho to create it again but that didn't happen so I took the file from Moho's official tool folder on the installation folder. I don't really know what I'm doing. But that may have fixed some of the duplicated tools, except one.
synthsin75 wrote: Fri Oct 08, 2021 11:06 am Tools can also have different file names but their internal function names are the same. These will show up as two tools, one with an icon and one without, but both will be using the same script (the last one Moho happened to load). This can happen with some custom scripts, where the file is not named with lm_ but the internal code is, to utilize some functionality that's only available to LM named functions.
Thank you, that pointed me in the right direction.
I realize that some of them were not duplicated but they were just meant to be menu scripts, because they didn't have an icon, so I put them as menu scripts.
Other scripts were modified versions of the official tools starting with lm but ended in a different way. I renamed those as the official name and that made them the official version of the tool inside Moho, but they kept showing no icon, so I went to Moho's installation folder and copied the official icons of that tool from there and pasted in my scripts folder. That solved it, they have icons now.
The duplicated tools I think got fixed by the mess I made with the tools list file, but there is still only one script that keeps being duplicated: the Select Keyed script by Hayasidist. Maybe it's because its from 2017... but I have the feeling that it may have something to do with the fact that I had a shortcut for that tool. My shortcuts panel shows empty rows at the "group of tools: other" section, and it also show other extra tool groups, the ones that got installed when I installed the Mynd tools (Group of tools: MYND_ANIM, Group of tools: MYND_MOVER, and more) but those groups are not working, they don't show up on the tools panel, or on the Edit / Preferences / Tool Layout panel, or on the tool list text file. Something is wrong with that.
Daxel wrote: Sat Oct 09, 2021 2:53 am ... but there is still only one script that keeps being duplicated: the Select Keyed script by Hayasidist. Maybe it's because its from 2017... but I have the feeling that it may have something to do with the fact that I had a shortcut for that tool. My shortcuts panel shows empty rows at the "group of tools: other" section, and it also show other extra tool groups, the ones that got installed when I installed the Mynd tools (Group of tools: MYND_ANIM, Group of tools: MYND_MOVER, and more) but those groups are not working, they don't show up on the tools panel, or on the Edit / Preferences / Tool Layout panel, or on the tool list text file. Something is wrong with that.
The tool itself (even my "Select Keyed" script) doesn't have any knowledge or control over which group it appears in. Of note, however, "Select Keyed" is a BUTTON not a TOOL (it has no UI), so if you've got a line in your _tool_list that refers to it as a tool that might explain the duplication?????
If you can upload your _tool_list.txt I'll take a look at it -- I'm wondering if the list moho is seeing might be different from the one that you might be looking at in an editor??????????????
hayasidist wrote: Sat Oct 09, 2021 5:22 am
oh, no I was calling it tool because I didn't know it was called button. I didn't see it as "tool" anywhere. My _tool_list right now is identical to the one on the official tools folder that is on Moho's installation folder:
/* anime_version 11200001 */
/* keyboard shortcuts are now set in the application */
/* for format compatibility placeholders are retained below */
group MOHO.Localize("/Tools/Group/Draw=Draw")
tool	lm_select_points	...
tool	lm_transform_points	...
tool	lm_add_point	...
tool	lm_curvature	...
tool	lm_freehand	...
tool	lm_shape	...
tool	lm_delete_edge	...
tool	lm_magnet	...
tool	lm_brush	...
tool	lm_eraser	...
tool	lm_pointreduction	...
tool	lm_scatterbrush	...
tool	lm_perspective_points	...
tool	lm_shear_points	...
tool	lm_bend_points	...
tool	lm_noise	...
group MOHO.Localize("/Tools/Group/Fill=Fill")
tool	lm_select_shape	...
tool	lm_create_shape	...
tool	lm_paint_bucket	...
tool	lm_delete_shape	...
tool	lm_line_width	...
tool	lm_hide_edge	...
tool	lm_curve_exposure	...
tool	lm_curve_profile	...
tool	lm_colorpoints	...
group MOHO.Localize("/Tools/Group/Special=Special")
tool	lm_switch_layer	...
tool	lm_particle_layer	...
tool	lm_crop	...
tool	lm_image_masking	...
tool	lm_video_tracking	...
group MOHO.Localize("/Tools/Group/Bone=Bone")
tool	lm_select_bone	...
tool	lm_add_bone	...
tool	lm_transform_bone	...
tool	lm_manipulate_bones	...
tool	lm_reparent_bone	...
tool	lm_bone_strength	...
tool	lm_bone_groups	...
tool	lm_sketch_bones	...
tool	lm_bind_layer	...
tool	lm_bind_points	...
tool	lm_offset_bone	...
tool	lm_bone_physics	...
tool	lm_wind	...
group MOHO.Localize("/Tools/Group/Layer=Layer")
tool	lm_transform_layer	...
tool	lm_set_origin	...
tool	lm_follow_curve	...
tool	lm_rotate_layer_xy	...
tool	lm_shear_layer	...
tool	lm_shape_picker	...
button	lm_insert_text	...
tool	lm_eyedropper	...
group MOHO.Localize("/Tools/Group/Camera=Camera")
tool	lm_track_camera	...
tool	lm_zoom_camera	...
tool	lm_roll_camera	...
tool	lm_pantilt_camera	...
group MOHO.Localize("/Tools/Group/Workspace=Workspace")
tool	lm_pan_workspace	...
tool	lm_zoom_workspace	...
tool	lm_rotate_workspace	...
tool	lm_orbit_workspace	...
So I don't really know why the shortcuts setting panel is messed up with those MYND groups and empty rows. But it probably has nothing to do with your script but with something I made with it. I think it was the only script that I assigned to a shortcut because I use it quite a lot.
Daxel wrote: Sat Oct 09, 2021 10:46 am
<snip>
ok -- the light has come on!! -- we're somewhat at cross purposes! you're now talking about shortcuts.. that's not the tool_list it's the key bindings... it's in your custom content folder -- in the Keyboard Shortcuts subfolder and it's called <your shortcuts name>.json -- and there does seem to be an issue with that ... I've just had a look at mine and there's a blank entry for a tool I was working on some while back - and I have since deleted it (i.e. the tool's .lua) but there's now an empty entry in the shortcuts screen (as you'll get from edit / edit keyboard shortcuts) where that tool once was.
it also seems that the tool's UI label is what that shortcuts screen uses -- so if the tool itself doesn't have a :UILabel() function I guess that will also leave you with a blank.
so --- if you can grab your <tool shortcuts>.json (it's a plain text file) and upload that ...
hayasidist wrote: Sat Oct 09, 2021 1:19 pm
I tried moving the shortcuts json out of the shortcuts folder to see if that file was the one to blame, but turns out it isn't. Now the shortcut settings is reset and it doesn't show blank rows or any of those MYND groups, but the select keyed button keeps being duplicated on the tool panel. So it looks like those are two different problems. The shortcuts one doesn't bother me too much, I understand that it simply doesn't update to remove unexisting tools or groups and I guess I can fix it modifying the json.
I felt that the problem had to be on the tool folder so I started removing groups of scripts by author and one of these times the select keyed tool wasn't duplicated anymore. Turns out the problem was caused by me as I expected, because the problematic file is hv_font, that is a font made by Heyvern that A.Evseeva included in her fantastic Modified Transform Bone Tool but she didn't expect me to put it in the wrong folder (I guess it goes in the utility folder). Why did it bully your script in particular? I don't know maybe because it starts with h so it was the closest one or something.
Thank you all for your help, learnt a lot, everything is fine now.
Seems it just duplicated Paul's script because the utility script was after it alphabetically and didn't have any working functions (UI, OnMouseDown, Run, etc.). Same thing happens with a completely blank Lua file.
