*NEW* Animated hide edge tool
Re: *NEW* Animated hide edge tool
Synthsin75 had moved some of his scripts recently and a few links had gotten broken. He's very good about fixing them once alerted so hopefully he'll see this soon.
Once you get the script, it's pretty awesome. While it's possible to do something like this manually, Synthsin75's script makes it a lot easier. This is one of those features I wish was built into Moho.
I've updated the first post with this new link: https://drive.google.com/uc?export=down ... j8RVx907A2
Ahh yeah that worked! Thanks very much, I appreciate your work!synthsin75 wrote: ↑Sat Oct 02, 2021 1:57 pmI've updated the first post with this new link: https://drive.google.com/uc?export=down ... j8RVx907A2
Awesome script, and it still works in v13.5.
I don't know if this is important or not. . .
In a new project, when I first hide an edge with the script, a bunch of console errors appear.
The names of the switch keyframes on frames 0 and 1 are "0,0,true,0,1..." and it goes on like that for about 50 characters.
I'm still figuring-out how the script works. In one of my test projects, I now have a lot of switch-groups for hide edge. Sometimes I don't get a new switch-group for a while even though I'm hiding a lot of edges, and then I get a new switch-group. What causes a new switch-group to appear? Is it okay to combine all the switch-groups into a folder to tidy-up my layers? It seems okay, but I thought I'd ask.
Is there a "best practices" way to use this script? Anything I should avoid? This script will be pretty handy. Thanks for making it.
It's been a while since I used this tool but I believe the switch group is being used as a container to hold Animated Hide Edge's keyframe data. There's probably info about this earlier in this thread.
Update: I just checked and, yeah, I guess somebody posted info about this before.
Here: viewtopic.php?p=183395#p183395
I'm not able to replicate that here. If you have specific steps, I can try again.Hoptoad wrote: ↑Mon Apr 03, 2023 5:42 pm Awesome script, and it still works in v13.5.
The tools needs a separate switch layer for each vector layer you use it on. Right now, this switch needs to stay in the same group as the vector layer, but you can move them all to the bottom of the group.I'm still figuring-out how the script works. In one of my test projects, I now have a lot of switch-groups for hide edge. Sometimes I don't get a new switch-group for a while even though I'm hiding a lot of edges, and then I get a new switch-group. What causes a new switch-group to appear? Is it okay to combine all the switch-groups into a folder to tidy-up my layers? It seems okay, but I thought I'd ask.
I have other things in the works right now, but I do have plans to revisit this tool. When I do, I'll include the ability to group all switches
Okay. I just created a new project containing only a star shape. I used translate layer to move it 48 frames. I moved the playhead to the 24th frame and clicked the script button, then I clicked on an edge of the star to hide it.
I immediately got the usual message about not moving the script-group, and also a lua console window that said, "...138:bad argument #1 to 'ipairs' (table expected, got nil)". The message was repeated around 20-30 times. The edge did not get hidden, by the way, but it did get hidden when I clicked it again. The tool continued to work from this point on.
I think this tool should part of core Moho. For Pete's sake, it's literally a new form of animation.
Still not able to replicate the problem, but that error gave me something to go on.Hoptoad wrote: ↑Mon Apr 03, 2023 6:24 pm Okay. I just created a new project containing only a star shape. I used translate layer to move it 48 frames. I moved the playhead to the 24th frame and clicked the script button, then I clicked on an edge of the star to hide it.
Try this new version and see if it still spits this error:
I replaced the script, refreshed Moho, started a new test project and got the same console error, except the number was 139 this time.synthsin75 wrote: ↑Mon Apr 03, 2023 6:49 pm Try this new version and see if it still spits this error...
I'm on a Mac. Sometimes that matters, so I thought I'd mention it.
EDIT
Wait a sec. I might've made a mistake.
Re-testing.
That did the trick. No lua error.synthsin75 wrote: ↑Mon Apr 03, 2023 6:49 pm Try this new version and see if it still spits this error:
Thanks!
NIce! Thanks for catching that bug. It never showed up on my end, so I'm glad my guess fixed it.Hoptoad wrote: ↑Mon Apr 03, 2023 7:26 pmThat did the trick. No lua error.synthsin75 wrote: ↑Mon Apr 03, 2023 6:49 pm Try this new version and see if it still spits this error:![]()
Thanks!
BigBoiiiJones
Does this work in v14?
No idea. I haven't had time to test a lot of scripts.
BigBoiiiJones
It seems to work
Thanks for testing it out. I'll give a whirl this weekend, just to be sure.
