aver shoot keyframe
- davoodice2
aver shoot keyframe
hi friends.
is there any script for over shoot keys ?
Re: aver shoot keyframe
Elastic interpolation.
I made a tutorial about Elastic interpolation some time ago, maybe it can be useful for you
- davoodice2
THANKS YOU.I made a tutorial about Elastic interpolation some time ago, maybe it can be useful for you
but its not good for character animation with complicated keys. I want make keys a little bit overshooted according to next frame.
It's not exactly what you are showing, but you can adjust the values to get close.
An alternative is to use Bezier/s.
Yes, that's an option too. The only issue I see there is it would require to setup every independent keyframe in the graph mode (or at least many keys).
That's why I was thinking about the elastic interpolation. Once you are happy with the numbers there, you could apply them to all the keyframes at once.
Also, you can use the 'Copy previous key' option in the timeline to be sure every new key follows the same values than the ones already created.
Why not just keyframe the overshoot, as in your picture?
- davoodice2
when I work in maya I use a script called tween machine.synthsin75 wrote: ↑Tue Aug 10, 2021 8:16 am Why not just keyframe the overshoot, as in your picture?
What it does is take the values of all the selected joints in the previous keyframe and the next keyframe and calculate the over shoot based on the requested percentage and sets keyframes.
and this is simple version.
now I convert keys to bezier and adjust them by hand.
Well get cracking on Moho scripting then. Nothing stopping you from doing this yourself.davoodice2 wrote: ↑Tue Aug 10, 2021 11:04 amwhen I work in maya I use a script called tween machine.synthsin75 wrote: ↑Tue Aug 10, 2021 8:16 am Why not just keyframe the overshoot, as in your picture?
- davoodice2
my question was not complicated.synthsin75 wrote: ↑Tue Aug 10, 2021 2:58 pmWell get cracking on Moho scripting then. Nothing stopping you from doing this yourself.davoodice2 wrote: ↑Tue Aug 10, 2021 11:04 amwhen I work in maya I use a script called tween machine.synthsin75 wrote: ↑Tue Aug 10, 2021 8:16 am Why not just keyframe the overshoot, as in your picture?
And the answer was simple too. Either elastic interpolation, keyframe the overshoot manually, or write your own tween machine for Moho (which is what people did for Maya).
- davoodice2
I decided completely ignore you from now.synthsin75 wrote: ↑Wed Aug 11, 2021 11:20 amAnd the answer was simple too. Either elastic interpolation, keyframe the overshoot manually, or write your own tween machine for Moho (which is what people did for Maya).
Good.
