Create floting window
davoodice2
Post by davoodice2 »
hello.
I am newbie in moho scripting.
Is there a way to build a floating window in Moho? So that he had access to the main window of Moho. :?:
Lukas
Re: Create floting window
Post by Lukas »
I've been experimenting and was able to create a floating window that has access Moho but it's unstable at the moment: ExperimentDialWindow.gif
More info in this thread.
gilcartunista
Post by gilcartunista »
Great Lukas!! If possible I would like to try it! Grateful!
davoodice2
Lukas wrote: ↑Tue Aug 10, 2021 4:37 am I've been experimenting and was able to create a floating window that has access Moho but it's unstable at the moment: ExperimentDialWindow.gif
amazing job ! this with moho's api?
Lukas
Post by Lukas »
davoodice2 wrote: ↑Tue Aug 10, 2021 11:10 amamazing job ! this with moho's api?
Yes Moho's API and some undocumented stuff mentioned in the thread I linked in my first reply.
gilcartunista wrote: ↑Tue Aug 10, 2021 5:28 am Great Lukas!! If possible I would like to try it! Grateful!
It'll just crash...
gilcartunista
Lukas wrote: ↑Wed Aug 11, 2021 12:45 am
It'll just crash...
OK Lukas! No problem, I test it anyway! Grateful.
the challenge (why it crashes) is, I think, to do with how the "moho" table is passed through to the "update" function (and I'm also guessing that the functions in that table are expected to be written in C / C++; so the "moho" that they get is C-friendly, and not LUA friendly.) Specifically, I haven't yet figured out how to invoke the functions that return properties that the "usual LUA moho" would give you using such as moho.layer
More here: viewtopic.php?f=12&t=33793&start=30#p198597
so if anyone can figure that out ...
davoodice2
can you share how to create a floating window? please :cry:
just interface.
Lukas
Post by Lukas »
Check out the code in LM_SetOrigin.lua
Also: http://mohoscripting.com/classes/LM_SimpleDialog
davoodice2
Lukas wrote: ↑Wed Aug 11, 2021 8:59 am Check out the code in LM_SetOrigin.lua
thanks man.
davoodice2
davoodice2 wrote: ↑Thu Aug 12, 2021 12:17 am
thanks you.
