hi.
I assign Shift + h to hide bone. Now when I want to rename layer or type into any text field ,it hides my bone instead renaming.
Text Field typing
- davoodice2
Text Field typing
Re: Text Field typing
Also happens to me. Only with shift+ letter. I've been using Bloq Mayus to write capital letters as workarround.davoodice2 wrote: ↑Sun Aug 01, 2021 5:56 am hi.
I certainly had this prob when assigning Shift + <key> to built-in function shortcuts.
Another work-around trick is to use Caps Lock to get those capitals.
HA. It sounded like some fancy software!
At least on Windows, an AutoHotkey script could fix this, as every text entry box is reported as a control called "Edit 1". Not sure when I'll have the time to look into that.
