Just had Moho crash while I was trying out the new quad mesh functionality. Normally Moho is absolutely fantastic about recovering the project on the next open, but this time (and a few times over the last couple weeks of working in 13.5) it didn't open the project, and told me the JSON was bad--or something like that anyway. Is this file still located somewhere?
Follow-up question: Is there no auto-save in Moho?
Recovery File Location?
Re: Recovery File Location?
The auto-save is where you're getting the corrupted files. You can look in C:\Users\*user name*\AppData\Roaming\Lost Marble\Moho Pro\13\Autosave to see if any good files or backups are still there.
There have been some problems in 13.5 with auto-save and stability, but hopefully the next update(?) will help with that.
AutoSave is kinda broken in the current 13.5 release, and it likely caused the crash you experienced. I suggest turning AutoSave off until the next update is released. You can disable AutoSave from Preferences/Documents.
Unfortunately, I suspect your file is damaged and not recoverable. In addition to disabling AutoSave, I suggest making incremental saves throughout the day, especially after making major changes to your project. (IMO, users should be doing this in any creative program anyway. It's risky to rely on a single saved version.)
For future reference, the files are saved here (on Windows):
C:\Users\[Your user name]\AppData\Roaming\Lost Marble\Moho Pro\13\Autosave
You might need to enable 'Show hidden files, folders, and drives' to see this location.
Edit: I must be typing too slowly. Wes' beat me to it again!
Sure hope that get's fixed! Moho's stability/crash recovery is (was?) one of the strong points of the program.synthsin75 wrote: ↑Thu Jun 24, 2021 12:53 pm There have been some problems in 13.5 with auto-save and stability, but hopefully the next update(?) will help with that.
Oh absolutely. I version up fairly often. Still, auto-save is a crucial tool to have in the war against lost work!
Anyway, thanks for the help y'all. I unfortunately couldn't recover the project, but have since decided not to use quad-mesh in the animation anyway. :p
You can also use the Help > Show Autosave Files link
And I highly recommend cloud backup - for backups.
Whaaa? Somehow I missed this new feature. Nice!
Thanks for the tip SimplSam.
Yeah, I had either missed or forgotten that. Thanks, Sam.
I'll third the 'thanks', that's super convenient.
