Please anyone can make a tutorial for this ????? Please!!!!!
striker2311
Post by striker2311 »
This is one I came upon on youtube but unfortunately cannot find its tutorial please anyone explain this or make a tutorial for this. I bet a lot of people will get benefit from this. Or if anyone already have the link for its tutorial please share it.
[youtube]https://www.youtube.com/watch?v=RCRN4un5jQM[/youtube]
striker2311
Re: Please anyone can make a tutorial for this ????? Please!!!!!
synthsin75 wrote: ↑Sat May 01, 2021 10:23 am Here's some more info on that technique.
http://www.lostmarble.com/forum/viewtop ... 11#p149711
And the first video here: http://www.lostmarble.com/forum/viewtop ... 28#p195828
when i'm selecting lower bone and changing max ik stretching to 100 , the lower leg bone scale doesn't change to normal after scrubbing timeline... Please help!!
striker2311 wrote: ↑Sat May 01, 2021 12:46 pm when i'm selecting lower bone and changing max ik stretching to 100 , the lower leg bone scale doesn't change to normal after scrubbing timeline... Please help!!
Is it targeting another bone? That's how the IK stretching works. It has to be told to reach for another bone.
If that doesn't solve it, we may need to see your file.
striker2311
synthsin75 wrote: ↑Sat May 01, 2021 1:17 pm
You were correct Thanks !!!
I fixed it :D
:cry: :( But now a new problem is raised pin bone that should be responsible for movement of upper bone even if I'm moving that pin bone the upper bone isn't moving.
[img]C:\Users\USER\Pictures\Screenshots\Screenshot (355).png[/img]
[img]C:\Users\USER\Pictures\Screenshots\Screenshot (354).png[/img]
Please help me!!!
striker2311
Here's the link of my file please check.
https://drive.google.com/file/d/1f1S5oC ... sp=sharing
striker2311 wrote: ↑Sat May 01, 2021 1:52 pm Here's the link of my file please check.
Access denied. Please PM me a regular link if you don't want it shared publicly.
striker2311 wrote: ↑Sat May 01, 2021 1:34 pm :cry: :( But now a new problem is raised pin bone that should be responsible for movement of upper bone even if I'm moving that pin bone the upper bone isn't moving.
If you're talking about the pin bone at the knee, having its position constrained to the "ankle control" won't allow you to move it manually. If you really want it constrained, you'll need to parent it to another bone you constrain. That will leave the knee pin bone free to be manually animated.
striker2311
synthsin75 wrote: ↑Sat May 01, 2021 9:32 pm
I didn't clearly get what you said :oops: can you tell me to which bone should I parent it to.
You'll need to make a new bone to parent to. So that bone can be position constrained to the "ankle control" bone, and the knee pin bone will follow that parent.
striker2311
synthsin75 wrote: ↑Sat May 01, 2021 10:04 pm You'll need to make a new bone to parent to. So that bone can be position constrained to the "ankle control" bone, and the knee pin bone will follow that parent.
Thank you thank you very much !!! You're a life saver sir it worked :D :D :D
Glad you got it sorted. :wink:
chucky
Post by chucky »
This method doesn't use ik stretching, but a hidden smart bone.
chucky wrote: ↑Sat May 01, 2021 11:32 pm This method doesn't use ik stretching, but a hidden smart bone.
It does for the limb foreshortening, starting around 11:37.
The smart bone is only used for sleeve perspective.
striker2311
synthsin75 wrote: ↑Sat May 01, 2021 11:41 pm
That's done :)
But now a new problem :( :cry: :cry:
My legs are streching too much i want them to be of a particular size what can i do to achieve that??
Here's my file please check:
https://drive.google.com/file/d/1tWt7R0 ... p=drivesdk
