16 Great Free Moho Pro Tools from Mynd
peterkajan
Post by peterkajan »
Hi Moho users! Please check this 16 fantastic Moho Pro tools we are giving out for free. I hope you will enjoy :)
Ideas and Management: Mynd, Coding: Mitchel Soltys & Derek Root. Download links are in video descriptions
PS: Click on that video to open playlist - each tool has it's own video tutorial.
https://youtu.be/v_5Cw5P-WoI?list=PLWae ... 9aaO-ssGLt
Gaucho
Re: 16 Great Free Moho Pro Tools from Mynd
Post by Gaucho »
peterkajan wrote:Hi Moho users! Please check this 16 fantastic Moho Pro tools we are giving out for free. I hope you will enjoy :)
Thank you very much Peterkajan!!!
Fantastic! Thank you very much!
Telemacus
Post by Telemacus »
Thanks PeterKajan, very kind of you!
mdmodeler
Post by mdmodeler »
Outstanding! Thank you so much!
troypicou
Post by troypicou »
Thank you!
I have no good excuse for not checking out Mynd Tools sooner, but I finally got around to it this weekend.
Man, I wish I had checked these out sooner! :)
Some of the Mynd tools are features I've been wishing for for some time, notably Switch View, Select Shapes, Round Corners, and Set Origin. Others, like Clone Offset and Insert Layers In Groups, are features I hadn't known I needed.
Excellent collection guys! Thanks for creating Mynd Tools and making them available to all!
DK
Post by DK »
Getting Lua errors on all of the Mynd Mover tools.
D.K
alanthebox
Post by alanthebox »
Hmmm... I'm getting quite a few crashes on both 13 and 12.5 after installing these scripts. Anyone else experiencing that? Also, is there a maximum number of installed scripts that can be displayed?
chucky
Post by chucky »
I thought Mynd didn't work 13.
DK
Post by DK »
My Mynd install is on 12.5.
D.K
Yes, I'm using Mynd in 12.5.
With Moho 13.0, I get errors with the Move tools too, but I'm not using 13.0 or the Move tools.
Tip: I have a folder in Scripts called scriptsPaused, and I drag scripts I don't currently use in there. Dragging scripts into a nested folder effectively disables and hides them.
ATM, I keep the Move tools in this folder since they're not something I typically need. If the need comes up, I can always drag them out. The ones I specifically mentioned earlier are the ones I will use routinely.
Greenlaw wrote: Tue Apr 06, 2021 5:39 am Tip: I have a folder in Scripts called scriptsPaused, and I drag scripts I don't currently use in there. Dragging scripts into a nested effectively disables them.
Great minds...I named that folder "Disabled". I regularly drag older versions of scripts I'm developing there as backup.
DK
Post by DK »
All the other tools seem to work fine all except the Move tools? I particularly would like to
use those ones.
D.K
That error is because you haven't stored any animation yet. IMO, there should be a default animation for each or just better error handling.
