Fix incorrect red crosses in layer panel?
Re: Fix incorrect red crosses in layer panel?
Lukas, I've used this hack in other scripts, and it seems to work for this too...from a button/menu script.
	moho.document:PrepUndo(moho.layer, true)
	moho.document:Undo()
So you can loop through and do this for all the relevant layers in the document.
Lukas
Post by Lukas »
synthsin75 wrote: ↑Tue Mar 09, 2021 8:06 am Lukas, I've used this hack in other scripts, and it seems to work for this too...from a button/menu script.
YES, WES! 💪
Thank you so much, that absolutely works!
(Also, thanks hayasidist for thinking along)
Lukas wrote: ↑Tue Mar 09, 2021 11:57 am YES, WES! 💪
I'm just glad I thought to try it for this. I needed this to update things while the timeline was playing.
Glad I could help. :wink:
