Hello, I have a doubt when creating a script Lua
bbrraayyaann
Post by bbrraayyaann »
Hello, I have used the page to create scripts. http://mohoscripting.com/new_script.php
I want to create a button, that when I click on it I import or load a .moho file directly. I have tried many ways but I do not solve it, could someone help me please, this is the code:
ScriptName = "upload"
upload = {}
function upload:Name()
    return self:Localize('UILabel')
end
function upload:Version()
    return '1.0'
end
function upload:UILabel()
end
function upload:Creator()
    return 'Brayan'
end
function upload:Description()
    return self:Localize('Description')
end
function upload:ColorizeIcon()
    return true
end
-- Is Relevant / Is Enabled
function upload:IsRelevant(moho)
    return true
end
function upload:IsEnabled(moho)
    return true
end
-- Keyboard/Mouse Control
function upload:OnMouseDown(moho, mouseEvent)
end
function upload:OnMouseMoved(moho, mouseEvent)
end
function upload:OnMouseUp(moho, mouseEvent)
end
function upload:OnKeyDown(moho, keyEvent)
end
function upload:OnKeyUp(moho, keyEvent)
end
-- Tool Panel Layout
upload.UPLOAD = MOHO.MSG_BASE
function upload:FileImport(path, mode)
end
function upload:DoLayout(moho, layout)
    self.uploadButton = LM.GUI.Button(self:Localize('upload'), self.UPLOAD)
    layout:AddChild(self.uploadButton, LM.GUI.ALIGN_LEFT, 0)
end
function upload:HandleMessage(moho, view, msg)
    if msg == self.CARGAR then
        self FileImport("D:\\El Aus Juego\\Personajes\\Auron personajes\\VioletaG.moho",1)
    end
end
-- Localization
function upload:Localize(text)
    local phrase = {}
    phrase['Description'] = 'this is the description'
    phrase['UILabel'] = 'upload'
    phrase['upload'] = 'upload'
    local fileWord = MOHO.Localize("/Menus/File/File=File")
    if fileWord == "Файл" then
    end
    return phrase[text]
end
Re: Hello, I have a doubt when creating a script Lua
First, it's best practice to always prefix your script function names with your initials, like "bb_upload" instead of just "upload". This makes sure scripts do not conflict with one another.
If you're making a button/menu script, it cannot have the mouse functions in it, as this tells Moho that it is a tool. You need: function bb_upload:Run(moho)
You do not need any GUI functions (DoLayout, HandleMessage, etc.) for a button that just does one thing. You just need to do that stuff in the Run function.
If you're calling another function in your script, you need "self:FileImport()" instead of "self FileImport()". And you use the Moho API file import function like: moho:FileImport(path, mode)
No need to create or call a new function for it yourself.
SimplSam
Post by SimplSam »
To echo the sentiments of Wes (synthsin75):
If you go back MohoScripting and create a new Button/Menu script - using just the options below - you will get a basic button script, and then you just need to add your (corrected) code in the Run function.
bbrraayyaann
Thanks synthsin75 , for the line moho:Fileimport(path,mode)
I have something like this, but I want the button (upload) to appear and when I click on it, it will load directly without pressing accept. thanks anyway, if you have an idea please correct me
ScriptName = "bb_upload"
bb_upload = {}
function bb_upload:Name()
end
function bb_upload:Version()
    return '1.0'
end
function bb_upload:UILabel()
end
function bb_upload:Creator()
    return 'brayan'
end
function bb_upload:Description()
end
function bb_upload:ColorizeIcon()
    return true
end
function bb_upload:IsRelevant(moho)
    return true
end
function bb_upload:IsEnabled(moho)
    return true
end
-- bb_uploadDialog
local bb_uploadDialog = {}
bb_uploadDialog.UPLOAD = MOHO.MSG_BASE
function bb_uploadDialog:new()
    local d = LM.GUI.SimpleDialog(bb_upload:Localize('UILabel'), bb_uploadDialog)
    local l = d:GetLayout()
    d.uploadButton = LM.GUI.Button(bb_upload:Localize('upload'), d.UPLOAD)
    l:AddChild(d.uploadButton, LM.GUI.ALIGN_LEFT, 0)
    return d
end
function bb_uploadDialog:HandleMessage(msg)
    if msg == self.UPLOAD then
    else
    end
end
-- The guts of this script
    moho:FileImport("D:\\El Aus Juego\\Personajes\\Auron personajes\\VioletaG.moho",1)
    return
end
-- Localization
function bb_upload:Localize(text)
    local phrase = {}
    phrase['UILabel'] = 'bb_upload'
    end
    return phrase[text]
end
bbrraayyaann
Thanks SimplSam, you also helped me I had not seen that option and I corrected it I have something like this :
but I want the button (upload) to appear and when I click on it, it will load directly without pressing accept. thanks anyway, if you have an idea please correct me.
bb_upload = {}
end
    return '1.0'
end
end
    return 'brayan'
end
end
    return true
end
    return true
end
    return true
end
-- bb_uploadDialog
    return d
end
    else
    end
end
    return
end
-- Localization
    local phrase = {}
    end
    return phrase[text]
end
try this for starters...
there are a couple of comments I've added to help especially with localisation.
if/as you're hard-coding the file name you won't need a dialogue ... obviously, if you're planning on adding to this you will.
and you should aim to give yourself an icon that will appear in the tools panel if this is more than a quick one-off... ask if you need info on the format / conventions for icons.
(tested ok - except ofc I don't have your file, so Moho threw the expected "can't find it" error)
bb_upload = {}
end
    return '1.0'
end
end
    return 'brayan'
end
end
    return true
end
    return true
end
    return true
end
-- bb_uploadDialog
--[[dialogue not needed??
    return d
end
    else
    end
end
    return
end
-- Localization
    local phrase = {}
-- this is for the Russian localisation; if you want to provide localisation to Spanish change Файл to Archivo
-- and provide Spanish text for the given phrases.
    end
    return phrase[text]
end
bbrraayyaann
Hello hayasidista, yes I tried it and it works the same as before. What I want is that the upload button also appears to press it and I just load the file.
For example here it says only "Message UPLOAD received".
And I want the file to be uploaded
bb_upload = {}
end
    return '1.0'
end
end
    return 'Brayan'
end
end
    return true
end
    return true
end
    return true
end
-- bb_uploadDialog
    return d
end
        print('Message UPLOAD received')
    else
    end
end
    local dlog = bb_uploadDialog:new(moho)
    if (dlog:DoModal() == LM.GUI.MSG_CANCEL) then
        return
    end
    moho.document:SetDirty()
    moho.document:PrepUndo(nil)
    -- Your code here:
end
-- Localization
    local phrase = {}
    phrase['Description'] = 'ggg'
    end
    return phrase[text]
end
bbrraayyaann wrote: Sun Feb 21, 2021 12:19 pm Thanks synthsin75 , for the line moho:Fileimport(path,mode)
It should only ask to accept if you use 2 as the second argument in FileImport (if doing it in the Run function).
If you really want a dialog with a button, there's no way to get rid of the OK and Cancel buttons, as those come automatically with a SimpleDialog.
EDIT: If you really, really want a dialog, you could do this:
bb_upload = {}
end
    return '1.0'
end
end
    return 'brayan'
end
end
    return true
end
    return true
end
    return true
end
-- bb_uploadDialog
function bb_uploadDialog:new(moho)
    d.uploadText = LM.GUI.StaticText("Do you want to import this file?")
    l:AddChild(d.uploadText, LM.GUI.ALIGN_LEFT, 0)
    return d
end
    if (dlog:DoModal() == LM.GUI.MSG_OK) then
    elseif (dlog:DoModal() == LM.GUI.MSG_CANCEL) then
	return
    end
end
-- Localization
    local phrase = {}
    if fileWord == "????" then
    end
    return phrase[text]
end
When the dialog comes up, you just have to hit OK or hit enter (same thing).
bbrraayyaann
synthsin75 -- Ah I understand I thought it could be done by pressing a button, thanks.
bbrraayyaann wrote: Sun Feb 21, 2021 2:19 pm synthsin75 -- Ah I understand I thought it could be done by pressing a button, thanks.
It can, by just putting the FileImport in the Run function. Then you only need to press the button in the toolbar...or even assign it a shortcut.
bbrraayyaann wrote: Sun Feb 21, 2021 1:24 pm Hello hayasidista, yes I tried it and it works the same as before. What I want is that the upload button also appears to press it and I just load the file.
bb_upload = {}
end
    return '1.0'
end
end
    return 'Brayan'
end
end
    return true
end
    return true
end
    return true
end
-- bb_uploadDialog
    return d
end
    else
    end
end
        return
    end
    -- Your code here:
end
-- Localization
    local phrase = {}
    end
    return phrase[text]
end
the version you have here is not the one I gave you -- I had commented out the dialogue (as synthsin said - if all you want to do is to press the button in the tool window, you don't need it); this version doesn't include Run function along with the moho:FileImport() call; and the the localisation you have is looking for the Russian language version - and, judging by the file name you used in the first version, you're likely to have a Spanish UI? so looking for the Russian word for "file" will always make the test (if fileWord == "Файл" ) evaluate to false.
SimplSam
Post by SimplSam »
I am now of the opinion that Brayan might want a Pop Up Dialog in addition to a Button on the dialog that loads the File (not necessarily the OK button). I suspect that this may be the start of something bigger.
Brayan can you please try and clarify even just by listing the user interaction steps - as another user would see it.
i.e.
1) Click Tool / Button
2) Review Dialog message
3a) Option: Click X to do Y
3b) Option: Click OK to do Z
3c) Option: Click CANCEL to Quit
bbrraayyaann
SimplSam wrote: Mon Feb 22, 2021 12:41 am I am now of the opinion that Brayan might want a Pop Up Dialog in addition to a Button on the dialog that loads the File (not necessarily the OK button). I suspect that this may be the start of something bigger.
haha no, all the answers helped me a lot, what happens is that I am very new to lua ; I just learned how the language works and there is not much information about it. That's why I'm also learning python to better understand the LUA language, about the SCRIPT I solved it, it was something simple that I didn't understand at the beginning.
