I never saw it that way, in my head when people is using flexi-binding on their vector rig they are trying to move the points with the bones, like the points of a hand with a hand bone. Layer binding only makes sense to me when you are controling the layer position.synthsin75 wrote: ↑Wed Jan 13, 2021 12:35 pm Flexi-binding is what bones do to image layers, so points being flexi-bound is not really point binding but a flexible layer binding...hence flexi-binding.
Yes, the tools shouldn't be under the same name. The concept could be Direct binding for both, to explain that both are forms of binding that are atached to a bone and influenced by it directly. But of course the tools should have their unique name, that's why I proposed Direct Point binding. With layers could be Direct Layer Binding. That would have made me understand what is actually happening, what characterizes that kind of binding and why there is also a different kind of binding called flexi-binding (that I called force-binding)Since point-binding and layer-binding are two different things (with different tools), it wouldn't make much sense to lump them under the same or an even longer name, like "Direct Point Binding".
Totally agree. I use the program in another language and I thought that the name was force, not influence, so Influence-Binding or Bone-Influence Binding would be much better options.Since there is no mention of "force" in Moho, except for physics, it would be better to stick with an existing reference, like "bone influence". So "Influence-binding" might work instead of "flexi-binding", but flexi-binding also implies that the artwork will be moved in a more flexible way. "Influence" or "Force" don't really convey that end result.
When you can see by the names that you can bind points to a bone directly or to the bone influence, you can start imagining that the influence binding is going to be flexible, but those names are only titles, that in my opinion should be complimented with contextual hints, like:
Direct Point Binding: "Instead of using influence binding, the selected points will be bond directly and only to the selected bone, ignoring its influence"
Something like that. Maybe everyone is different but at least in my head that would have been much clearer.
