Curve a layer path?
uncle808us
Curve a layer path?
Post by uncle808us »
Is there an (easy way) to curve a layers path? Or must I change each keyframe? I tried follow path but could not figure out how to stop and hold a layer mid path while following the path. this question is for Anime Studio Pro 11.
Thanks very much for reading and I appreciate any and all help to find a solution.
Sincerely Bob
I use a MacBook Pro, and Anime Studio Pro 11.2
http://uncle808s.blogspot.com
Re: Curve a layer path?
You can keyframe stops anywhere you like, using the follow path tool.
I don't remember if it was in v11, but if you have show path enabled on the transform layer tool, you can also ctrl/cmd-click anywhere on the path to sculpt and keyframe it.
uncle808us
@synthsin75: Man that was fast. Thanks. I found it in the manual right after I posted. I should know better than to post before checking the Docs.
Sorry, but I do appreciate you answer.
