MOHO basics?
MOHO basics?
I feel like I'm missing some information on Moho that may seem to basic for most people to think about. I've run into a problem. I'm unsure of how to get the add point tool to create lines that aren't curved. Very simple it seems, but the real problem is that I am unsure of how to go about finding the fix to this problem for myself. Does anyone have a link to basic knowledge that I may have overlooked with this software?
Re: MOHO basics?
When you add a point it usually will be a curved one like the ones before and after. Select a point, cmd-P for Peak, cmd-C for curve, a line between two peak points will be straight.
Re: MOHO basics?
Also, before adding any point, you can select the Add points tool and check 'Sharp corners' in the tool's properties.
- MrMiracle77
Re: MOHO basics?
Moho defaults to curves. You can either enable sharp corners (banner at the top when you have 'add point' selected) or you can use the curve tool (next to add point) to change the curvature after you've added the point (click and drag left/right for sharper/curvier).
I find it easier to start with sharp corners and make them curvy than to start curvy and make them sharp.
- Dave
(As Your GM)
(As Your GM)
