Clearing Green Marker from Timeline Frame Count
Little Yamori
Post by Little Yamori »
Hi All,
Not sure how I did this, but using my tablet pen I accidentally hit the timeline and it added a green marker to my timeline frame count area and now the animation only begins from this spot. In my project settings it still shows it beginning from frame 1, but because of this marker, it only plays from the middle of the animation where the markers set. I don't know how to remove it so I can render from frame 1.
As always, any help is much appreciated
LY
Little Yamori
Re: Clearing Green Marker from Timeline Frame Count
Well,
I just saved and closed the file and re-opened it.
Problem Solved--no more green marker starting point
SimplSam
Post by SimplSam »
The Green Marker is the IN marker for playback. There is also a Red Marker for OUT. These can be used to play-around a limited / partial segment of the timeline.
You can use Ctrl+LeftClick on the timeline ruler to set/unset the In (Green) Marker, or Ctrl+RightClick to set/unset the Out (Red) marker.
