Lua 3rd-Party Libraries Not Loading
mminsel
Post by mminsel »
Hi,
I have the following issue:
I'm running Moho 12 on Win 10.
Moho 12 contains Lua version 5.2 x64 (I think.. as _VERSION returns 5.2 and running prebuild libraries with x32 gave me an dll error).
So I compiled the Lua-socket module linking it against version 5.2.4 x64.
I installed it to a dedicated folder and have set the LUA_PATH and LUA_CPATH variable in my CMD.
When I launch Lua in this CMD everything works.
When I now launch Moho from the same CMD and run the following commands from a tool in Moho it doesn't work:
http = require("socket.http")
r, c, h = http.request{method = "GET", url = "http://www.google.com"}
Instead it complains saying:
Error loading module: /path/to/cpath/socket/core.dll: The module wasn't found.
I wonder if this is a conflict with the internal Lua version? What Patch version is included in Moho 12 and how can I get the exact version number and possibly the arch (x64/x32)? (_VERSION just gives me 5.2)
If the Lua version matches: Is there any restriction in using third-party dlls in the Moho-Lua?
The LUA_PATH, LUA_CPATH and PATH look correct in Moho.
mminsel
Re: Lua 3rd-Party Libraries Not Loading
Post by mminsel »
I actually recompiled it in x32: I don't get the
but only the
So the problem persists
mminsel
Post by mminsel »
I switched to version 13 of Moho. What I get is:
With Lua 5.2.4 and 5.2.0 x64 I still get an immediate crash.
with Lua 5.2.3 and 5.2.1 x64: Error: Multiple Lua VMs detected.
Googling this error gave me two possible reasons:
1. The version of Lua is not exactly the same as the one I'm linking against
2. The Moho executable is not linking lua dynamically
So I guess that the latter may be the cause of the issue.
Once upon a time, Moho could find dlls in a modules folder in the scripts folder, but I don't think that functionality has worked since, maybe, v10 or older.
As far as I know, Moho uses Lua compiled in its executable, so even if you get it to find another Lua build, it's always going to find that compiled one as well.
Defims
Post by Defims »
means moho main program already embeded a lua vm. if you require a dll which embed a lua vm either, error will be throw out.
I think the best solution is expose the lua vm in moho main program for user defined usage.
SimplSam
Post by SimplSam »
Defims wrote: ↑Tue Mar 22, 2022 10:17 pm
An alternate solution is for LM to upgrade the Moho embedded Lua to 5.4 - which allows multiple VM's.
Rai López
Post by Rai López »
So it was not only me... I've spend several days already trying to make LuaSocket to work with Moho with similar errors like...
error loading module 'socket.core' from file 'D:\Ramon0\Projects\Animation\Moho Pro\Scripts\Modules\socket\core.dll':
The specified module could not be found.
...in my case, but I thought it had more to do with me not using the exact binaries (I've not been able to find the ones for Lua 5.2.4 64-bit, and I've been testing every other binaries I could have find out there). Although I see now that it surely wouldn't have worked anyway.
What a pity, because it would open a whole new world of scripting possibilities... Really nobody has got to make it work? Even if not with LuaSocket but with any other package? It seems so close, because for the error one could think that at least Moho is correctly accessing the dll file, but then encountering some problem finding the specified module in it.
synthsin75 wrote: ↑Mon Nov 25, 2019 2:52 pm Once upon a time, Moho could find dlls in a modules folder in the scripts folder, but I don't think that functionality has worked since, maybe, v10 or older.
Regarding that, I've found this line in an old changelog:
  • 2012-10-19 - Fixed Bug #25606 - Lua dll modules are now properly loaded from the user scripts/modules folder.
So, in theory, at some point that issue got some attention from devs, but who knows if maybe it wasn't then tested well enough or whatever :cry:
Ramón López wrote: ↑Thu Oct 27, 2022 6:32 pm
It was working at one time, as I had an eyedropper tool that could pick colors outside of Moho. It used a Lua 5.1 and a custom color picker dll.
I no longer have v11 installed, but I checked, and it doesn't work in v12 or 13.
Rai López
Post by Rai López »
My hopes were dashed then... But at least now I can stop trying, thanks for taking the time of testing and confirming. Sincerely, all that LuaRocks for Windows and everything is totally way over my head, so I've been trying everything that was in my hand for not having to deal with installing it and compiling and all that, and when I was about to do it turns out find this, who knows how much time I would have had to invest for nothing otherwise. Well... let's try to move on then...
Rai López
Post by Rai López »
synthsin75 wrote: ↑Thu Oct 27, 2022 6:56 pm I no longer have v11 installed, but I checked, and it doesn't work in v12 or 13.
🤔 But, out of curiosity, did you get similar errors as the ones mentioned above? I mean, do you also have the feeling that Moho/Lua is actually being able to "read" inside the .dll but, for whatever reason, having troubles to find whatever it's needed to find in there? I'm not quite sure where I'm going with this question... I guess the fact that Moho seems to be able to get into the .dll module still gives me some kind of hope? (Even though I just said I was going to move on 🙄).
Ramón López wrote: ↑Thu Oct 27, 2022 7:38 pm
Some part of it still seem to work:
If you put the dll anywhere except the modules folder, Moho complains about not finding it.
And this error does seem to involve Moho reading the dll, but I'm not sure I still have the source files to verify that.
EDIT: Nope, that error is just because the dll was written for 32bit. If I launch v12 in 32bit, I get this instead:
...which doesn't seem to be reading anything in the dll.
Rai López
Post by Rai López »
Argh... OK, I think I kind of resisted to believe it was indeed totally broken, but that's what it seems... Again, thanks for taking the time of testing it and posting all the details.
Maybe if I could write/get a very simple .dll file I'll be able to do some more tests starting from the simplest kind of module calling possible and see, but I feel so lost when it comes to deal with something different than Lua, and more if it involves compiling and such kind of stuff, that I'm not sure till what point that will be possible. Well...
Yeah, it's been years since I made that dll, and I'd have to relearn everything again.
Rai López
Post by Rai López »
So you made it from scratch?? I wasn't sure if it would be simply part of a third party library or something... Dude, how I hate it be so easy to forget certain so valuable stuff, but at least you can argue that have passed years, it starts to happen to me from one week to another :lol: ( :( )
Defims
Post by Defims »
WOW, Moho 11 is nice! I wonder how to pass the color value back to Moho in your color picker dll, Is it some code like:
lua_pushstring(L, "#000");
Is it possible to call other function? like:
lua_getglobal(L, "CHANNEL_BONE_3");
