Point Select tool Issue
Yosemite Sam
Post by Yosemite Sam »
Hey guys, I've finally switched over to Moho 13 permanently. I noticed the points select tool default has changed. I now have to hold control to get the lasso function. Does anyone know how to reverse this? I use the lasso about 99% of the time, so this is quite frustrating. I looked through preferences, but couldn't find a solution there. Thanks!
Jimmy Mills
Some of my Moho Pro work.
Re: Point Select tool Issue
There's a lasso checkbox in the tool options, and control temporarily toggles to the opposite of that setting. The new install is likely set to the default.
Yosemite Sam
synthsin75 wrote: Sun Nov 24, 2019 6:30 pm There's a lasso checkbox in the tool options, and control temporarily toggles to the opposite of that setting. The new install is likely set to the default.
how did I miss that... thanks again Wes.
Jimmy Mills
Glad I could help. :wink:
