Opacity for "Frame by Frame" dosen't work v13
Tylos
Post by Tylos »
Hi,
It looks like opacity for "frame by frame" gruop layer dosen't work. It shows up only in renders. MOHO 13
Re: Opacity for "Frame by Frame" dosen't work v13
Unfortunately, that's how it's always been in ASP/Moho: effects applied to any group layer (Group, Bones, Switch, etc.,) only show up at render time.
I wish it showed up in OGL too. A while back, I was told they were looking into re-working how Moho uses OGL, so hopefully we'll start seeing such improvements.
Tylos
Post by Tylos »
Thanks, for replay.. I still learning moho... I will keep it in mind....
This is very old post just checking to see if it's the same thing happening to me now.
I have nested group layers so I can easily use opacity to fade in and out. Sadly, opacity only displays "live" for the "first level" layers in the main layer with opacity set. All the subgroup layers won't display opacity.
It keeps messing up my renders because I can't see that I have partial opacity halfway through a scene, because I can't see it until it's rendered. Just checking if this is still an issue.
