tool for align .
Deepurana749
tool for align .
is there any tool in moho to arrange the point shape or to align them properly like path finder in illustrator
Re: tool for align .
Other than the grid, no.
Deepurana749
is there any method for custom your own brushesslowtiger wrote:Other than the grid, no.
- hayasidist
do you mean making your own custom brushes? - If so, yes -- take a look at: viewtopic.php?f=13&t=32558&p=185907Deepurana749 wrote:is there any method for custom your own brushes
Unfortunately, no.
As a workaround. I usually make guide lines (using Add Points) or grids (using the Grid tool) in their own layers so I can scale and position them over or under the art points/shapes/layers I'm aligning. Unfortunately, no snapping but it works well enough most of the time.
Tip: If you enable Paths in the layer's Quick Settings, the guides are visible even where they're not stroked and not selected.
For guides I use a lot, I keep a folder for them so I don't have to keep re-creating them, and I can import them into any project.
As mentioned above, there is an editable Grid that has snapping. It's fine for quickly aligning elements at regular intervals but it's also awkward to edit. And because every layer has its own local grid settings, it's use is somewhat limited between multiple layers. I use like to use it to align my SBDs but not for much else.
