Mouth Switch Error
Leon13DM
Mouth Switch Error
Post by Leon13DM »
I am trying to make an animation that uses a voice clip I made. I used a voice changer to give my voice a more cartoonish effect, but this seems to have had an effect Moho's Voice Recognition ability, as when I assigned the Mouth Layers to switch to the voice, it only does so after every 30 frames. Is there a way to modify the voice recognition settings to fix this? Heck, I'd even take an option that randomly switches the mouth layers. I just don't want to input the switch frames individually myself.
Re: Mouth Switch Error
I assume you're doing the final render from Moho? If so, how about you have two audio files -- one the voice you want to hear and one to control the mouth - set the mouth switch to use the "control" track but set its "visibility" to off (use the "eyes" icon).
(If you're using a video editor it's a different approach)
Shizukuishi
Post by Shizukuishi »
It seems the sound wave is a little flat. You could try to amplify it on an audio editor (e.g. Audacity) to gain higher peaks.
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
Leon13DM
Post by Leon13DM »
I attempted to raise the audio in Moho using the Audio File's option menu, but the switch remains the same, even when the waves are increased. I tried the first method as well and it didn't work.
Leon13DM wrote:I attempted to raise the audio in Moho using the Audio File's option menu, but the switch remains the same, even when the waves are increased. I tried the first method as well and it didn't work.
Raising the volume in Moho doesn't change the audio's amplitude. You'd need to do that in an audio editor, like Audacity.
Leon13DM
Post by Leon13DM »
I tried Audacity and it works now.
