Total noob here...
Total noob here...
I want to create samurai animation...2 problems here:
1. when character A slashes catan character B loses head (how separate head)
2. ....then blood spalshes from neck.
Obviously sorry for my poor english
Re: Total noob her...
You should make two new copies of your character at this keyframe. (where the charatcer loses it's head). One copy with just a head and the other copy without the head. Now turn off visibility for the main character (with head). Animate/drag the head off the body and animate the headless version falling to the ground. (or whatever). Make a new layer and draw some blood splashes flying out of the headless version.
Cheers
D.K
Cheers
D.K
My store on Renderosity:
ok first part is clear.... but when i draw blood at frame 0 i dont know how make it to appear at right moment and disapper one second later.
Use layer opacity or layer visibility to show/hide it at the right moment/keyframe. Make sure you turn on "Allow Animated Layer Effects" when you double click on the layer for these things.
Cheers
D.K
Cheers
D.K
Thanks man
now I understand some basics
cheers
cheers
A couple of months ago, I learned from another user here that you don't need to enable 'Allow Animated Layer Effects' to keyframe Visibility. This is also true for Flip H and Flip V, but everything else in that section of the panel requires the option to be enabled for keyframing. A bit inconsistent, I know, and I turn the option on just to make sure everything is keyframeable.DK wrote:...Make sure you turn on "Allow Animated Layer Effects" when you double click on the layer for these things.
TBH, I'm not sure why we have this option at all...to me, it's just one more unnecessary click.
Basically the same reason we have Enable Drawing Tools Only On Frame Zero, which I never use (and I always use Allow Animated Layer Effects). People complained about getting keyframes where they didn't intend them to be, because they didn't realize they weren't on frame zero. So, a programming solution for a user error problem.Greenlaw wrote:TBH, I'm not sure why we have this option at all...to me, it's just one more unnecessary click.
You could always write a script that would enable animated layer effects for the whole project at once, to save some clicking. Actually, we could probably use a project default script that has options for many things, like bone bind method, layer ordering, animated layer effects, etc..
I can see that for drawing because you really can mess stuff up by unintentionally drawing on a later frame. I usually have this on until I actually need to draw on a later frame.
And I guess I can also see that for some of the other Layer properties where it's less obvious that your creating keyframes.
I agree this should be an optional project default so long as enabling the option isn't adding unnecessary channel data to the scene. (Sorry, I know we had this same discussion only a couple of months ago.)
Anyway, no biggie. Just wanted to point out that the option wasn't necessary in the above case.
I did not know that Greenlaw thanks for the heads up. Probably not necessary but good practice for a new user. That script would be very handy Wes.
Cheers
D.K
Cheers
D.K
Here you go: https://sites.google.com/site/synthsin/ ... ects=0&d=1DK wrote:That script would be very handy Wes.
Just run this menu script to make every layer in the project Allow Animated Layer Effects.
That's very cool, Wes! I'll give it a try this evening.synthsin75 wrote: Here you go...Just run this menu script to make every layer in the project Allow Animated Layer Effects.
Thanks for making this.
Your script works very well!synthsin75 wrote:Here you go: https://sites.google.com/site/synthsin/ ... ects=0&d=1DK wrote:That script would be very handy Wes.
Thank you very much Synthsin75!!!
