RELEASE: Mohoptimize
Next
Post by Next »
hi spasmodic_cheese!!!
I have Flash MX 2004 and Macromedia Exchange but is impossible install Mohoptimize because your extension is mxp and says that onlyit is for FireWorks.
When I installMohoptimize, Macromedia Exchange says: "The installer file is invalid. The extension will not be installed"
NEXT :shock:
spasmodic_cheese
Post by spasmodic_cheese »
ummm use the Extension Manager not the exchange thing.
I downloaded it and it works fine on all my machines
Visions of Domino
Post by Visions of Domino »
Ummm... the link doesn't work anymore. Can anyone supply it?
Well, I have only MX (not 2004) but I'm hoping that I could still run it.
spasmodic_cheese
Sorry guys
http://www.lungshrimp.com/mohoptimize/mohoptimize.mxp
there you go, it wont leave there for a very long time :)
I havent updated this as I have been working on something much better.
Enjoy!
Visions of Domino
thanks, but unfrtunately, not compatible with my Extension Manager. :( Ah well, I tried.
spasmodic_cheese
you need at least FlashMX04, it also works with flash8. If not you can always downlaod the latest extension manager from macromedia
Voxel
Post by Voxel »
If you break up the mmexecute command over a number of frames - ie, process first 10 frames, return, process next 10 frames etc. instead of in one big for loop you shouldn't get the 'your script is running slowly error'
Alternatively you can use Flasm to alter the script limits tag in the bytecode for your swf
http://www.nowrap.de/flasm.html#scriptlimits
spasmodic_cheese
thanks, im well aware of this, but i havent updated and wont be since it was first made, I only put it back up cause i got tired of people messaging me for broken link.
have you seen?
http://www.buraks.com/swfsli
I have been working on something MUCH better than mohoptimize :)
which im going release this week
feel free to edit it or modify mohoptimize if you can improve it
Voxel
Post by Voxel »
Alas I too am time poor! :(
I had seen that - but lost the link - I just went with the top o googles list.
JSFL is brilliant.
