*NEW* Stacked shape tools
https://drive.google.com/uc?export=down ... Uudoxbqjad
For Moho v14: https://drive.google.com/uc?export=down ... 1tSn9CoCUs
Create shape tool:
  • This mod allows you to create stacked shapes on the exact same vector points.
    • Warning: Stacking too many shapes can cause aliased edges when rendered.
      The select shape tool will help you avoid that.
  • Update 7/4/19: This now displays selected end points as fat markers.
Select shape tool features:
  • A shape stack indicator: Shape ID: 0 [1] 2
    • When you select a shape, this shows all the IDs for the shapes below the cursor.
    • It indicates which shape in the stack is selected with "[ ]". So you can see either your selection change, using Ctrl+Up/Down, or the shape order change (IDs move), just using Up/Down.
    • Left to right is top to bottom in the stack.
  • No more Ctrl+Up/Down overrun...where you keep hitting the arrow and nothing happens.
  • You can also make contiguous shape selections in the stack using Ctrl+Shift+Up/Down. All selected shapes in the stack are indicated by "[ ]" and can be moved as a group.
:D :!: :!: :!:
ulrik
Re: *NEW* Stacked shape tools
Post by ulrik »
That is indeed a very useful tool, thank you for sharing this! :)
Updated the above link to correct a minor issue.
onurbeiren
Post by onurbeiren »
it will help a lot!
:arrow: :arrow: Image :!: - :idea:
https://www.youtube.com/user/animadorporacaso
Creator of the first Group Brazilian Anime Studio(Moho Pro 12): https://www.facebook.com/groups/998442436875703/
A.Evseeva
Post by A.Evseeva »
Oh, thank You very very much, it is very helpful!
I even wanted to write such a tool, but could not imagine how shoud an interface look like. Your idea is simple and perfect!
Sometimes the tool can not see some shapes.
(two shapes selected but only no 11 shown)
Here is the file.
Also I have a tool mod wich can show an outline of selected shape. Maybe You want to implement it into Your tool?
It looks like this:
A.Evseeva wrote:Oh, thank You very very much, it is very helpful!
Yeah, I kicked myself for not thinking of it earlier.
Here is the file.
It doesn't show all selected shape IDs. It only shows all selected and unselected IDs under where you last clicked.
In your picture, the hair line is shape 11 (selected) and the hair fill is shape 9 (unselected). The ear is shape 17, so you probably selected that and then shift-selected the hair line (shape 11).
It looks like this:
Interesting. Since there's already a checkerboard pattern, maybe I could use that to highlight the whole stack.
Is that mod in one of your existing tools?
A.Evseeva
Post by A.Evseeva »
Oh, thank You! Now I understand how does it work. I missed that I have to click to see numbers under cursor.
Here is my function for tracing shapes
function LM_SelectShape:TraceSelected(moho, view)
	local mesh = moho:Mesh()
	if mesh == nil then return end
	local g = view:Graphics()
	local matrix = LM.Matrix:new_local()
	moho.drawingLayer:GetFullTransform(moho.frame, matrix, moho.document)
	g:Push()
	g:ApplyMatrix(matrix)
	for s = 0, mesh:CountShapes()-1 do
		local shape = mesh:Shape(s)
		if shape.fSelected then
			for e = 0, shape:CountEdges()-1 do
				local c,p = shape:GetEdge(e)
				local startPercent, endPercent = mesh:Curve(c):GetSegmentRange(p)
				local step = (endPercent-startPercent)/10
				local p1 = mesh:Curve(c):GetPercentLocation(startPercent)
				for i=1,10 do
					local nextPercent = startPercent + step * i
					if nextPercent > endPercent then nextPercent = endPercent end
					local p2 = mesh:Curve(c):GetPercentLocation(nextPercent)
					g:DrawFatLine(3, p1.x, p1.y, p2.x, p2.y)
					p1:Set(p2)
				end
			end
		end
	end
	g:Pop()
end
Thanks for the tracing function.
This looks cool, Wes! Will try it out this evening.
Per Victor's request here: http://www.lostmarble.com/forum/viewtop ... 20#p188420
Link: http://www.lostmarble.com/forum/viewtop ... 90#p184390
Create shape tool:
This is great! Thanks Wes!
alanthebox
Post by alanthebox »
I installed this script tonight and have been playing around with it, but I'm having trouble understanding the application for it. Would someone fill me as to how you would use this in one of your projects?
Sorry, I'm sure it's super obvious but I feel like I'm missing it!
alanthebox wrote: Sat Jul 06, 2019 3:11 am I installed this script tonight and have been playing around with it, but I'm having trouble understanding the application for it. Would someone fill me as to how you would use this in one of your projects?
The stacked shapes? Here's an example from Denis: https://www.lostmarble.com/forum/viewto ... 63#p184363
Chucky used to have a very nice example of a desk lamp that really showed off the potential of shape stacking, but I'm not finding it.
chucky
Post by chucky »
Well this is well over ten years old.
Good memory Wes.
Because the shapes are stacked on the same vectors, it's possible to change the entire shape and all the effects move with it.
That's it, Chucky. It's memorable because it makes an impact.
