*NEW* Import layer comps script
Posting this before I forget to.
https://drive.google.com/uc?export=down ... Pm35GcLek1
With this script you can either import characters (or other Moho objects), with all the layer comps that include the imported layers, or import just the comps for all selected layers.
chucky
Re: *NEW* Import layer comps script
Post by chucky »
Awesome .. thanks Wes
Hey, Wes. Do you still have this script?
I need to export several scenes and I need to create dozens of layer comps for each one, but these scenes are all using the same layers, actually. If your script can import layer comps from one file to another one with the same layers, it would save us a lot of time!
Thanks!
Víctor Paredes wrote: ↑Thu Nov 18, 2021 2:31 am Hey, Wes. Do you still have this script?
Just updated the link, Victor. Hope it helps. :wink:
Hi Victor,
I'm sure Wes will address this soon but for now I sent you a copy of the Menu script.
It's very handy if you create many layer comps for compositing that you need to use over and over again.
With the way Moho's Layer Comps works now, it gets tedious to have to keep recreating layer comps any time a character or other setup is imported to a new project and needs to be rendered. Wes' script eliminates the problem.
IMO, this feature needs to be native in Moho. I would also like to see export/import options in the Layer Comps window, as well as options for generating special passes (like solid masks, strokes only, fills only, etc.,) that can be used for lighting and fx work in a compositing program. Right now I need to create these passes manually in Moho by referencing rigs and building special alternative artwork layers for them...this is very time consuming and it seems to me that Moho should be able to do this internally and automatically. (The Kung Fu Panda footage on my last reel is a good example of this process.)
Anyway, I hope this is what you needed.
Ah! I see Wes got to it as I was typing. (As usual!) :D
Thank you very much, Wes! I will check it first thing in the morning :)
Thanks, Dennis! I will take a look there too.
I have been thinking a lot about Layer Comps lately (we have to separate so many things in this movie! :roll:)
It works perfectly!
Thank you so much! It is already saving me hours of work!
(I'm way happier than this message can transmit)
Glad to hear it, Victor. Always nice to know when some forgotten script has been useful.
Oh, it's definitely useful Wes! As are many of your scripts and mods. :D
Don't get me wrong, I assume there are people still using many of them...and I appreciate when you and others suggest them. Just don't know when they're getting new users until someone reminds me of a broken link or asks about or mentions one. But I don't get disheartened if one seems forgotten. Just nice to know one of the orphans found a new home.
Hey, Wes! Writing to let you know that this script still works great in Moho Pro 14!
It had been a while since I last used it (probably Moho 12.5,) and I was a little worried that it wouldn't work...but it worked perfectly! Whew!
Thanks once again for creating all these excellent tools!
synthsin75 wrote: ↑Fri Nov 19, 2021 9:19 am Don't get me wrong, I assume there are people still using many of them...and I appreciate when you and others suggest them. Just don't know when they're getting new users...
A user in Discord asked about adding the ability to include Layer Comp settings during import. I mentioned your script, so expect some new visitors. :D
Thanks, Dennis.
