how to export/import actions from one moho file to the next?
tfc
Post by tfc »
Hi there,
I am having a problem, I wanted to export some actions which I created in one Moho file into another Moho file, but I don't seem to find any way to do so.
Can anybody help me on this one?
:shock:
Or might it be that it is not possible to export actions at all?
tHANX ALREADY
Rai López
Post by Rai López »
...It's NOT possible actually! (incredible, isn't? :) ) But well, could be two peculiar ways at least... one of they could consist in take advantage of that macton's MARVELOUS "Save/Load Layer Animation" menu scripts to simulate such a task! I was experimenting something with this in the past and I think it worked to me 8) , but remember that you must copy the desired Action to the Mainline first to can use the script and viceversa, a little mess... I thought too about make some changes into that scripts to can Export /Import Actions directly (avoiding the Mainline steps), but I had not enough Lua knowledges :( and not enough yet... Even could be dangerous mix Actions with Scripts, but if possible (and if macton doesn't mind) maybe I should take up again the idea and run the risk... CIAO!
