Physics inside a closed circle
zoesan
Post by zoesan »
Hi and welcome back to a New Year. I've been attempting to use physics inside a closed circle, with another ball within it to bounce off of the sides, used the folder to enable physics etc, but can't to date get it to work. Looked at 'key framing it' just doesn't quite look right, but may have to work on that further.
Re: Physics inside a closed circle
physics in the set-up you describe works fine and as expected here - what's the actual problem you're having?
zoesan
Post by zoesan »
Hi Hayasidist my attempts so far haven't worked. I've set up the folder and layers in the folder, made the group folder named physics enabled, placed the other two vector layers inside - red ball is enabled and the other named non moving is 'enabled checked' and 'non moving' checked. The red ball drops a approx half a centimetres only - key frames made in timeline. TinyPic is no longer showing at all at the moment to upload.
zoesan
Post by zoesan »
What I've found is that if I make a rectangle shape and cut out the middle with a circle it works. Otherwise it doesn't when ball is placed inside a closed circle at my end.
Well, doesn't that sound logical? Collision detection means recognising solid shapes. If you place some object inside another solid object, how should the software know what you mean? If you cut out a hole in a shape, you have empty space inside solid walls again, and it works fine.
zoesan
Post by zoesan »
Slowtiger, assuming there is no other method, I'd like to have more than one ball, and dropping into the now cut out circle shape from the rectangle, got any ideas how this can be achieved, there is no way I know of to cut out an entrance into the the circle via the rectangle containing the circle, so the balls can drop in. Once ball is out of the perimeter containing the cut out circle, the ball no longer responds to the physics of being inside but now just responds to the outer perimeter of the rectangle.
zoesan
Post by zoesan »
One work around may be opacity setting. Will give it a go.
you could have two copies of the ball:
copy1 already in the circle with physics off and not visible
copy2 outside the physics group and visually in front of the solid part of the container
animate copy2 arriving "in" the container, at which point:
switch visibility to copy1
physics nudge copy1
zoesan
Post by zoesan »
Thanks Hayasidist like the sound of that, at the moment trying to keep numerals like on a Bingo number from remaining in place whilst the physics is operating, attaching to bones presently doesn't work.
zoesan
Post by zoesan »
Looks like just place text on same layer as bouncing ball instead of a separate layer.
jezjones29
Post by jezjones29 »
I'm not 100% sure what you're after, but maybe this will help:
https://www.animestudiotutor.com/shared_files?id=491
nice one Jeremy! (now we know what the actual problem was!)
zoesan
Post by zoesan »
Hi Jezjones, thanks for that, I did research on the web, but never came across this, the animation content in the process of making, with the aide of you animators out there, is being modified virtually live, since watching this video, ( I will watch again ) will now go back to the drawing board, the animation is for an article I'm putting together on Douglas Adams titled 42.
