Some channels doesn't applied when PLAY TEST
master2015hp
Post by master2015hp »
Hi there, after i finished making an action, when i tried to playback it to test how does it look.
Everything go fine but Layer Translation channel wasn't applied.
But if i insert a copy into Main TImeline, it played normally as it should with Layer Translation channel applied
Well, so i wonder what caused this, anyone else got this problem and how to fix? Thanks guy
Lychee
Re: Some channels doesn't applied when PLAY TEST
Post by Lychee »
I think you cannot control the position of a bone in a smartbone action, but I may be mistaken.
It would be nice to have a document telling us the rules about smartbones, knowing what it is possible or not possible to do.
Best regards.
master2015hp
Oh hi Lychee, it was not Bones' position but Layer's position.
I think it is a bug but i am not sure about that.
Did you check it?
Lychee
Post by Lychee »
Sorry for the late reply.
I created a little test on my side and everything worked fine.
It would be easier to share your file (if possible) to define whether it is a bug or a building error.
Do you have that animation channel muted in the action?
