closing hand - 2 FBF experiments
exile
Post by exile »
Using Chucky Kenway's FBF template.
The first gif is based on four images, for the second I used 13 frames from a movie as reference and strove for a hand-drawn look. The first, simpler one is probably more effective.
In the "How Do I" forum Wes helped me with the problems I had with accidental duplicates of frames.
http://singadream.com/4forumfriends_htm ... sLarge.gif
http://singadream.com/4forumfriends_htm ... 3Large.gif
Steve
http://www.youtube.com/user/toonlyrics
Music Website: http://www.singadream.com
Re: closing hand - 2 FBF experiments
I agree, the first one is better.
chucky
Post by chucky »
Looks good Exile.
You might get even better results with the taper settings off. 8)
exile
Post by exile »
chucky wrote:Looks good Exile.
You're right, I had them on for the 4-frame attempt, or rather, Moho had them on as default, as you pointed out in your tutorial.
I have one question: in the tutorial, you copy the clean layer and put it over the fill layer. Does that replace the fill layer? What is the purpose of the copied clean layer?
Steve
chucky
Post by chucky »
Oh, I copied that layer, so that I could use the bucket fill to fill in those shapes quickly... if you work it out , it actually does some gap closing, not as effectively as clip studio or TB but to some degree, you will see in that video that I sometimes use the blob brush to' help' fil; those gaps , or just use the bob to colour.
I sometimes kill all the shapes and leave the vectors when doing that but I didn't that time.
What would be really good would be if the bucket could use another layer as a fill 'guide' , like Clip Studio ( and toon Boom 'sort of') does.
Also then you could maybe even use that guide layer to guide the blob brush not to go outside the line- also like clip studio.
Keep in mind that the blob is only for rough filling, it needs a lot of improvement to be taken seriously, but it can get you over the line in the right circumstances...namely keeping it lose.
