One fairing option not available on Moho is Exponential. This is needed if you are doing an "infinite zoom/track" - the one which goes from a shot of the entire world, then tracks into a continent, then city, house. person, etc down to molecular level. Usually, this is many shots grouped together: Its tricky to set up and without this formula, you're never going to do it ... when working on 4 Dino's in New York (aka We're Back) for Universal, I had to calculated a move from 22F (22" inches wide" to an equivalent 0.25F zoom - it took 3 separate backgrounds and a week of Lynx Robotics software to calculate the Zoom, NS, and EW axis positions, including preparationof the field guides. To make it really fun, the move linked into an animated take-over and morph
Ah, the good old days of film ... I miss them. (Really, I do).
Back to the numbers. The great thing about this formula is that contains just 6 lines of code, with only one line of number-crunching. It's simple, elegant but a vital bit of maths. Don't even think of asking how I arrived at the answer or figured it out - just accept it works.
okay, here is the code (in Python)
#     Exponetial calculation vr: 1.00
#         (c) 2006 TJ Francis
#             Open Licence
# just credit me if you use it commercially
position_a = 4.0                    # --- start position of move
position_b = 16.0                   # --- End Positof of move
Frames = 8                          # --- How many frames, difficult, huh?
import math                         # --- include the math module
#--- Calc --------------------
unit_a = math.log(position_a)       # --- Convert to Log values
unit_b = math.log(position_b)
inc = (unit_b - unit_a)/Frames      # --- find the "linear" step value
n = 0                               # --- Intialize the variables
value = 0.0
for n in range(Frames+1):
    value = math.exp((unit_a + (inc*n)))        # --- generate the positions
    print n ,"  ", '% 6.1f' % (value)           # --- Echo the results
If someone wants to convert to lua script, then fine. I think this is of more interest to LM, which is why its .py.
I have a working python-code slow-in/constant/slow out formula - this one is linear fairings (soft stop): I am working on the radian fairings now - should have that finished by the week end. The documentation is taking a little time, as is the quirky nature of python code - I'm used to Pascal ... I cannot get the multi-dimentional array creation to work at present, and its driving me nuts (error is unknown function: array). I have now installed MubPY and hope that fixes the problem.
Any other idea why a = ([1, 2, 3], [4.0, 5.0, 6.5]) throws an error? I usually drop all the cruched numbers into a table, then just refer back to them for printing, driving motors etc. Saves on dual pass calculations.
Rhoel
