		batchScript = "~/mohoimpd"Code: Select all
		local homeDir = os.getenv("HOME")
		batchScript = homeDir .. "/mohoimpd"Next, I got this error message:
This probably means the batch file "~/mohoimpd" wasn't executed and therefore the file "mohodlst.dat" wasn't created by the batch script.CC:Relink Lost Images wrote:
So that boils down to the following code not being executed properly:
	local result = os.execute ( batchScript ) --no chmod??Anyway, if I comment out theProgramming in Lua wrote:The function os.execute runs a system command; it is equivalent to the system function in C. It receives a string with the command and returns an error code. For instance, both in Unix and in DOS-Windows, you can write the following function to create new directories:The os.execute function is powerful, but it is also highly system dependent.Code: Select all
function createDir (dirname) os.execute("mkdir " .. dirname) end
os.remove (batchScript)Code: Select all
cd "/Users/renevanbelzen/Desktop/relink images/"
ls -d1>mohodlst.datIf I execute this file in my BASH CLI, this dialogue appears:
CP756652-A:~ renevanbelzen$ ./mohoimpd
-bash: ./mohoimpd: Permission deniedCode: Select all
CP756652-A:~ renevanbelzen$ chmod +x mohoimpd
CP756652-A:~ renevanbelzen$ ./mohoimpdAnd indeed, if you execute
ls -d1I changed the script by inserting the chmod command:
	if(platform == "unix") then
		local permission = os.execute ( "chmod +x " .. batchScript ) -- chmod
	end
	local result = os.execute ( batchScript ) -- executeThe code at the end of the CC_RELINK_LOST_IMAGES.createSubDirList function produced this error, probably because the unix command "ls -d1" doesn't do what it is expected to do.CC:Relink Lost Images wrote:
Judging from the name of the function (createSubDirList) I guess the "ls -d1" command should have created a list of all subdirectories over all mounted drives.
Please give me some feedback on this, because I'm really in the dark here. I'm not exactly sure what I'm doing or are supposed to do next.
 I didn't really try this out before I posted this about RCEnvironment. I removed the .MacOSX folder, logged out and logged in again (.MacOSX folder still removed) and the script kept working. This is a good lesson for the future: don't assume something works or doesn't work.
