I have problem to totally understanding how the PSD is connected with scenes. In short, PSD gets disconnected some cases and it won't connect them back, to be more precise, Moho (12.2) won't save the connection and I can't figure out why.
More detailed situation description:
1. Used Moho workspace to set up file structure (scenes, pictures, rigs, renders)
2. Added project folder path to library
3. I built the rig with psd fail (saved in pictures folder)
4. Saved rig working scene under "scene" folder
5. When finished, saved rig layer to "Rig" folder (with library +button)
6. I try to load rig from library, psd is disconnected, I have to select it again every time and I can't figure out how to connect it again, permanently. Selecting missing picture files could be bearable, but it also disconnects the files when trying to export. It appears so that every time the rig is saved to another folder, than the original "scenes" folder, it loses the connections.
Could anybody comment this situation?
Thank you!
ps. Beside that, I love the way Moho works, it's simple, elegant and performs very well
