A question about importing layered photoshop files
I'm at work, otherwise I'd probably just give this a try myself... but when importing a layered photoshop file, and have a series of layers for hand positions, to be switch layers, am I correct in assuming even these hand layers are the same size/dimensions as the overall image itself? Or upon import, does Moho behind the scenes trim out all the unused transparent space?
Re: A question about importing layered photoshop files
Moho trims away any transparency.
- hayasidist
... and leaves the images "in the right place" by translating the layer in x/y
Thank you... I was a bit worried about imported layered images with lots of switch layers for mouths, hands, etc... This alleviates some of the worry I had.
