freehand with same outline width
I wanted to use the freehand tool to draw something but the problem with it is that it starts to get thinner until it disappear ! is there is a way to make the outline width the same?
Re: freehand with same outline width
Look at the settings. There is a way to change the effect.
Dale
Dale
Check the Freehand tool Options:
There you can play with different options for the tool. Try unchecking Taper start and Taper end.
ok!so to get the same width all I have to uncheck taper start and end! thanks alot now I can use my pen instead of shapes with the mouse which makes things a lot easier!Víctor Paredes wrote:Check the Freehand tool Options:
