Blob Brush - strange undo problem
Lebostein
Post by Lebostein »
1. Draw a first shape with blob
2. Release the mouse button and draw a second shape
3. Select Edit / Undo (to remove the second shape)
4. Draw the second shape again
--> If you release the mouse now, the first shape will change!!!
You can repeat this thing, the first shape deforms more and more (without touching it)...
https://dl.dropboxusercontent.com/u/134 ... _blob1.png
https://dl.dropboxusercontent.com/u/134 ... _blob2.png
https://dl.dropboxusercontent.com/u/134 ... _blob3.png
Re: Blob Brush - Undo problem
It's funny...I think I saw exactly what you are talking about when I first tried this, but then I tried a new example and I can't repeat it. I'll try again later.
I wonder if Point Reduction is being applied to the entire layer when undo-ing the second shape? I guess this could cause the shape to change a little (or maybe a lot, depending on the settings.)
Re: Blob Brush - strange undo problem
Sorry, I just realized you have images linked. Yeah, that looks extreme.
It seems like it doesn't happen if you have Merge Strokes enabled. Are you seeing that too? I'll ask about this.
Lebostein
Post by Lebostein »
Bug also exist in Anime Studio 11
chucky
Post by chucky »
To prevent this, a workaround is to create separate blob shapes.
Press enter and you will start a new blob shape, thus protecting the previously drawn shape.
That's the only way for now.
Lebostein
Post by Lebostein »
Thanks, but I search no workaround. I wanted to report the bug.
chucky
Post by chucky »
:lol: Don't worry it was reported some time ago.
If you don't want the workaround ... I'll take it back. :mrgreen:
lwaxana
Post by lwaxana »
somewhat related to this issue, the eraser tool sometimes functions as an eraser, other times it adds paint as though it was the blob brush. I've observed this behavior when using a mouse. I haven't observed it when using a tablet pen.
