All of my svg files are importing as black shapes
macmonkey_1975
Post by macmonkey_1975 »
Hi everyone,
I can export SVGs from affinity designer without any issues, but when I try to export from illustrator all of my shapes are black when they are imported into Moho. Are there any particular settings i should be using in illustrator?!
Many thanks in advance
Dave
Re: All of my svg files are importing as black shapes
I believe you have to export as AI8 or earlier.
parseh
Post by parseh »
Alternatively you can export it as SVG Tiny 1.2. You should have no problems.
macmonkey_1975
thank you guys, thats much appreciated, it was the svg tiny 1.2 that i was missing. Illustrator 8 works too but the colours are closer to the original illustrator file with the svg import (see attached).
Thanks again,
Dave
renchandl30
Post by renchandl30 »
OMG. Thanks. This helped me out so much. I was wondering what I was doing wrong cause I was having the same thing with the black shapes.
studiosjj
Post by studiosjj »
It's also a good idea to not have any gradients, effects or transparency applied when moving from illustrator to Anime/Moho
