[FIXED] Moho Pro 12 - Sub-Frame Motion blur glitch
- Pierre Gombaud
UPDATE 2: (after 12.1 update)
The problem is fixed! No more trouble with sub-frame motion blur on bitmaps.
It is still bugged when sub-frame motion blur is applied to imported 3D obj and shape layer converted to 3D.
I hope it will be fixed in a next update, as the potential is huge in my eyes. Good job, guys!
So, I've got a character made of bitmaps (single .PSD with layers imported individually), with smart warps for deformation and bones.
When I add no motion blur or basic motion blur, there is no glitch when I do export to video (on Windows 10, H264-ACC).
But, if I enable sub-frame onto motion blur, the face is completely messed up.
Here is a video to show you the results, with these differents motion blur settings:
https://3.sendvid.com/kk81xgmi.mp4
I can provide the .moho file if needed.
UPDATE:
I tried to render without "Multi-threaded rendering" and no more glitch.
But the render time is way longer, obviously...
If I render with "Multi-threaded rendering" enabled and in a JPG image sequence,
it is still bugged, but the output is even different! Weird.
My computer: MSI MS-1781 - GT72 2QE (laptop)
GPU: nVidia GeForce GTX 980M (mobile) / drivers: 369.09 (old drivers, I've updated to 372.54, rendering is still bugged).
DirectX: 12.0 / OpenGL: 4.5.0 NVIDIA 372.54 (# ext: 385) / OpenCL: 1.2 CUDA 8.0.0
CPU: Intel Core i7-4980HQ (Crystal Well) @ 2.80 GHz / drivers: 10.0.14393.0 (Microsoft) (seems to be the latest version).
RAM: 32GB DDR3 @ 798.14 MHz (4x Kingston 8GB)
OS: Windows 10 x64 Family Edition - Build: 14393.51 (the last update, I think)
UPDATE:
Last edited by Pierre Gombaud on Tue Oct 18, 2016 5:56 am, edited 5 times in total.
Re: Moho Pro 12 - Sub-Frame Motion blur glitch
I found the same glitch, bug, on my Moho 12 running OS X
I have reported it as a bug but that was with my computer specs , maybe you should do it as well!
Regards Ulrik
Regards Ulrik
- Pierre Gombaud
Ulrik, I've updated my initial post since, as there is a workaround, if I export with "Multithread rendering" disabled, the glitch is gone.
Downside is rendering time takes ages... I guess the problem might be related to the CPU?
I've send an e-mail to support.smithmicro.com
Certain features, like motion blur, that have to take each frame into account, in order, are not likely to work with multi-threaded rendering, since it divides up the frames between different CPU threads.
Yeah, I've noticed that it renders okey if multi-threading is disabled but is it really that way it's supposed to be?XZS wrote:Ulrik, I've updated my initial post since, as there is a workaround, if I export with "Multithread rendering" disabled, the glitch is gone.
Synthsin, you said "certain features" is being affected by the multithreading render, can you tell me more?
What features?
- Pierre Gombaud
That totally makes sense. But wouldn't it be possible to, say, calculate the frames on 3 cores and do a final "pass" for the motion blur on the last core?synthsin75 wrote:Certain features, like motion blur, that have to take each frame into account, in order, are not likely to work with multi-threaded rendering, since it divides up the frames between different CPU threads.
Then we can at least use 3 cores, the last one being used solely for the motion blur. As you can imagine, I'm not an engineer
Not as far as I know, because the motion blur has to be composited into each frame as it is rendered.XZS wrote:That totally makes sense. But wouldn't it be possible to, say, calculate the frames on 3 cores and do a final "pass" for the motion blur on the last core?synthsin75 wrote:Certain features, like motion blur, that have to take each frame into account, in order, are not likely to work with multi-threaded rendering, since it divides up the frames between different CPU threads.
- Pierre Gombaud
From my tests, I can use multithreaded rendering with subframe motion blur on vectors without any problem/glitch/bug, so motion blur can be composited this way?synthsin75 wrote:the motion blur has to be composited into each frame as it is rendered.
It is when I use bitmaps instead of vectors that I get some terrible results.
- Pierre Gombaud
Re: [FIXED] Moho Pro 12 - Sub-Frame Motion blur glitch
The problem is fixed! No more trouble with sub-frame motion blur on bitmaps. Even with "mutli-threaded" activated.
