Arms and Legs bend (using onionskins)
sillyanimate
Post by sillyanimate »
I learned this while watching an anime studio tutorial, using onionskins to adjust bones pivot point.
1. Go to a frame, (I normally do frame 24)
2. Go back to frame 0
3.Turn on onionskins for that keyframe
4. Translate bones
-you can now see when you move the bone the layer bind to it will change pivot
5. Make adjustments as needed
Don't forget! No one is perfect!
Re: Arms and Legs bend (using onionskins)
That is a great technique! I remember using it in a project some time ago, but then I totally forgot it!
Thank you for sharing it
anthillmob007
Post by anthillmob007 »
brill...i'll use it
strider2000
Post by strider2000 »
The onionskin is a nice technique. Thanks for sharing. If you're specifically wanting to do the round connections, like for elbows or knees, you may be interested in this technique if you don't already know about it.
https://www.youtube.com/watch?v=3blziEo7rDs#t=15m59s
sillyanimate
Thank you, for the technique, sometimes using the rounded ends isn't enough because sometimes it gets choppy in one area.
