Guess I should report that because the additional shortcuts you posted above are too useful to be kept a 'secret'.
Cool. Thanks. This is an interesting thread.synthsin75 wrote:Strider, I think this might be doable, with a few slight quirks. Give me some time, and I'll see if I can sort out what needs to be done.
If you mean this: Suppose I have 5 switch layers. I don't need to close and reopen in order to have the icons pop up to select for animating. But if I add a 6th layer, or alter one of the 5 layers, then I'll need to close and reopen my file (or even ASP) in order for the "icon selection layer/panel/dialog" to be updated with the new changes.synthsin75 wrote:it looks like you'll need to restart (close and reopen) AS to update the icons for new/edited layers.
Yeah, you'd only need to restart AS after you:strider2000 wrote:If you mean this: Suppose I have 5 switch layers. I don't need to close and reopen in order to have the icons pop up to select for animating. But if I add a 6th layer, or alter one of the 5 layers, then I'll need to close and reopen my file (or even ASP) in order for the "icon selection layer/panel/dialog" to be updated with the new changes.synthsin75 wrote:it looks like you'll need to restart (close and reopen) AS to update the icons for new/edited layers.
I don't think that's a deal breaker at all. In my mind this is primarily about making it easy and fast to select the correct hand position while animating.
Greenlaw wrote:Ah, mystery solved. it was the lower eyelids occluding the top of the mouth, which of course are not visible when the eyes are open because of a mask. Which is also why moving the Eyes Switch behind the Mouth Switch worked. Just something to keep in mind.
Funny, I was typing that just as you posted your tip, so you guessed it! Thanks for looking into this for me.
Super coolsynthsin75 wrote:This is looking very good.
Yeah, hopefully I didn't steal any of your steam on the idea. I just had an idea of how to implement it, and by the time I did a proof of concept, I had enough done to keep going.strider2000 wrote:Super coolsynthsin75 wrote:This is looking very good.... and no I don't mind detours
I'm always happy to help as I can with code or whatever, but it seems like you've already moved on. The biggest challenge for me is always calendar time
My real job is nearing schedule deadline. Code freeze in one week and absolutely no room for missing the target
I'm looking forward to the script!
