Special Effects software
sillyanimate
Post by sillyanimate »
Hi I use Anime Studio Pro 11 on my computer....
I want to make like a magical girl Anime or cartoon...
Any good software for special effects?
I am kinda on a budget
And I like something easy to use and HD export
Don't forget! No one is perfect!
Re: Special Effects software
Particle layers in AS.
Particle layers, glow effects, masks with lots of blur, animated colour changes, animated masks, layer blend modes. It's all there.
I'll add frame-by-frame to that list for "pop" / "wham" / "fizz" / "transform" / ... splashes.
If you can say or sketch out the concept of what you want in more detail I'm sure there'll be loads of help
Your main problem with research is to know the right term for a certain effect. Was it glow? fog? beam? or what?
Usually first I search for a good example image from a show/ film I can name. The I google "what's the name of that effect in (film title) at (time code)" Some otaku out there surely has asked this before. With the correct name, I google "how to do (effect name)". In most cases I will get Photoshop tutorials, or AfterEffect. Study these. You will find tools which are just the same in AS, only have different names. The basic concepts of masking, blur, blend mode, layer order are the same in all programs.
dueyftw
Post by dueyftw »
Flame Painter.
Dale
neeters_guy
Post by neeters_guy »
Flame Painter 3 doesn't export animation, but a companion product just released called Amberlight 2 does.
Another particle effects software is Timeline FX.
ruscular3d
Post by ruscular3d »
Special effect on the cheap I would recommend Dogwaffle's software called "howler 9.6"
sillyanimate
Sadly, I don't want to pay monthly or yearly payments for after effects.
herbert123
Post by herbert123 »
sillyanimate wrote:I guess will use after effects....
to YouTube I go
So you've taken out a subscription, right?
Psmith
Post by Psmith »
OpenToonz also has an extensive set of FX built into the software. Probably more effects than most people will ever need. Also, OpenToonz has particles which can be used in conjunction with these effects.
Here is a tutorial showing how to use shading and glow effects:
https://www.youtube.com/watch?v=FcZ2pnC ... Ob&index=3
Greg Smith
HitFilm Express is free. It's a subset of the full program but maybe it can help you with what you want to do. I'm not exactly sure what's missing from the free version but it might be worth a look. I mainly use the plugin version of HitFilm's tools for AE and they have some really unique and useful fx tools.
By 'Magical Girl, I'm guessing you mean like Sailor Moon or Puella Magi Madoka Magica? If so, I think this might do the trick.
