Any advice for doing a lip sync for 3/4 (front and back)and side views?
The front view is easiest sadly the others not so much
I am using Anime Studio Pro 9
I am not use I should use masking for the sideviews
Help?
Lip Sync For Side views?
Don't forget! No one is perfect!
Re: Lip Sync For Side views?
Hi mate,
I see no difference in side-view vs front view ... the process is the same in my opinion ... correct me if I'm wrong ?
If you say front view is easy then why not use the same technique for your side view or 3/4 view.
Just use different poses for each mouth position and 'switch' between them like in the video below :
Note that in the example no masking is used in the side view ... masking is only used in the front view mouth.
If you want a smooth transition from front to side then it's a different story I guess ...
There's some movies out there on how to make head turns and open mouths ... an example would be this :
Hope this helps,
-K.
Hope this helps,
-K.
