We'll just realizing how confused I am now that I'm working with Pro. Is there a way to test a standard bone rigging on frame "0" instead of frame 1 in Pro. I used to rig everything in debut 6 on frame zero, and move a bone with bound points immediately after hitting "bind points" while still in "0", but it seems pro doesn't work that way so your forced to make an unwanted keyframe on frame 1 just to test a movement. My brain says this can't be right, but so far I haven't figured out how to avoid it.
As usual thanks in advance, hope I won't have to keep asking simple questions, but I'm facing a lot of confusion with the differences in pro.
LY
Testing Rig in Frame "0"??
- Little Yamori
Little Yamori
Creator at http://www.IslandBuddies.com
YouTube Channel: http://www.youtube.com/user/GECKOT0WN
Re: Testing Rig in Frame "0"??
Manipulate bone tool.
- Little Yamori
Didn't work when only using a single bonesynthsin75 wrote:Manipulate bone tool.
I was experimenting with a simple one bone head rig and adding smartbone dials for expressions, when I went to tilt the head it would not work with the manipulate bone tool, it only moved the shape around like translating a layer, only when I added a second bone did the manipulate bone tool work, but only on the child bone. (can't say this is an improvement)
Thank you for the help though, it made me explore it more and kept me from going nuts
Little Yamori
Hold the alt key to rotate a root bone.
- Little Yamori
Thanks Synthsin75,
Alt key worked perfectly. Don't know why it had to be changed from the simple way it used to work, I'm sure it has to do with some coding process mumbo jumbo etc...(Argh) but thank you, it feels like a splinter has just been removed.
LY
LY
Little Yamori
It was changed because, while animating, there are much fewer times you need to rotate the entire character, but there are many time to translate it, like walk cycles.
Little Yamori, congrats! Looking forward to seeing your progress.
Cheers, Larry
- Little Yamori
Well, I guess it was just bad luck on my part that I experimented with a single bone at first and got really confused in order to find this out, but now that you explained the Alt key, at least I can get done what needs to get done. Thx again.synthsin75 wrote:It was changed because, while animating, there are much fewer times you need to rotate the entire character, but there are many time to translate it, like walk cycles.
LY
BTW 3deeguy, I'm still having a heck of a time in ASP 11 getting my dials and smart bones to behave, so things might take a little longer than anticipated (as usual)
Little Yamori
