Replace to layer in Photoshop file
ernpchan
Post by ernpchan »
Via scripting I can replace an image to a separate file. Is it possible to replace to a layer in a Photoshop file? We can import layered Photoshop files. I'm not seeing a way to manually swap out Photoshop layers.
My opinions and comments do not represent those of my employer.
http://www.ernestpchan.com
http://www.zazzle.com/gopuggo
Re: Replace to layer in Photoshop file
Check out my old Syn_UpdatePSD script to update a psd import (I haven't used it in ages, so no idea if it works with AS11). http://www.kelleytown.com/forum/animato ... PIC_ID=760
You have to parse the psd to determine the layer IDs and hierarchy, then parse the AS document to match these and change the source image using the ID in the psd (line 147):
moho:LayerAsImage(moho.layer):SetSourceImage(path.."*"..id.."*")
ernpchan
Post by ernpchan »
Thanks! I'll check it out.
ernpchan
Post by ernpchan »
synthsin75 wrote:Check out my old Syn_UpdatePSD script to update a psd import (I haven't used it in ages, so no idea if it works with AS11). http://www.kelleytown.com/forum/animato ... PIC_ID=760
Is there a way to get access to this script without having to register with another forum?
Nope, but registration's free and many more scripts are only found there.
ernpchan
Post by ernpchan »
synthsin75 wrote:Nope, but registration's free and many more scripts are only found there.
Ok, I'll join that forum too.
Just curious but what's the difference between that one and this one?
Smaller, more active scripters.
