...Oh,Oh! I can't Manipulate Dynamic Bones in 5.3.1
Well, at first I frightened very much
¡, I thought that we had lost this USEFULL function forever, uf...
but now seems that must be some oversight that only affects to Manipulate Bones tool, cause I can Rotate Dinamics bones with Rotate Bone tool along the time but not Manipulate'em with Manipulate Bones tool... You can easily try it with a simple Dinamics chain of bones and see it. Well, how I always have loved the possibility of animate Dynamic Bones
(against the "Controlled Bones" LIMITED way of work
) I hope (what a heck! I totally trust
) it'll can be easily resolved... CIAO!
- Lost Marble
Couldn´t one manually move bones that had dynamics in earlier versions of Moho?
Example: Say one wants to really snap a tail on a horse.
One would add bone dynamics to the tail, then in the first frame move the tail bone all the way to the bottom, several frames later move it all the way to the top to add that extra momentum and whip of the tail through the bone dynamics.
Now one can´t manually move the tail bone with dynamics - the tail bone with dynamics is stuck in one position. If the rest of the bones in horse don´t move, the tail doesn´t move and then there are no motion dynamics to whip the tail.
...LM!!! This is NOT possible! Sorry, but we ALWAYS have had the possibility of animate Bone Dynamics, why suddenly we can't??? Oh, sorry, SORRY, I'm little altered, I know... (I need to breath, uf... uf...) but I can´t believe it yet... PLEASE I'd ask for a reconsideration (PLEASE) this was a vey USEFULL function and one of the main reasons for I loved Dynamics, what have happened in this 5.3.1?? Why this involution? There must be another alternative to resolve the problems that eliminating/limiting very usefull and consolidated features... I think that we can't going in REVERSE (gear)! Please, really this is a very bad notice to me
and my workflow and I hope only be dreaming/Nightmaring (HOPE), well... Bye...
- Lost Marble
You can still use the Rotate Bone tool to rotate a bone with dynamics, so this is how you would approach the flipping horse tail example. It's just that the Manipulate Bones tool cannot move dynamic bones. This was a requested feature: the idea is if you have a leg or arm with dynamic bones in it (muscles, kneecaps, flabby arms, etc.), these dynamic bones will be ignored by the Manipulate Bones tool. You will only be moving the main parts of the arm, and the dynamic parts will move according to the physics simulation.
Sorry LM, I'm treating to understand you but I can't... Before of this change it was possible do all that you say without any problem and we could animate Dynamic Bones with Manipulate Bones tool since 5.0 beta... Now is not possible and I can't see the benefits
...I know that you must have your SUPER powerful reasons and probably you are a little tired about this issue, but I'm very intrigated for the change cause with it I'm feeling a little less free during animation works and it's not good...
THANKS for/if any attention! (more...)
HI LM! Again with this issue, yes... Ammm... sorry... Well! As you can see it's still a problem to me (all right, not my mayor problem actually but one more to add to the list...) The difference is that I understand now your purpouse with this 5.3 "fix", but if you test this Moho file in a previous Moho version you will know why I could not feel the benefits in the past and even actually...
The issue is that, as you can see, I had my own efective "Tip and Technique" to solve the Dynamics Chain Manipulation issue in previous Moho versions and that is the reason for the supposed benefits are become for me in a little waste... Well, the thing that I only want to coment is: Really is TOTALLY impossible the coexistence of the two ways? Wouldn't be possible that Manipulate Tool could dissable Dynamics temporaly (just meantime you hold RMB) in the IK chain and then dynamics recover the normality when you release Button without timeline keyframes insertion? ...I have seen that "temporaly" lua comands in the LUA reference (fTempPos, fTempLength, fTempAngle, etc...) and I'm very curious about that... I don't know, maybe a silly thing or not (although I'm sure you could find a better solution...), but well, my intentions are good and... Finishing, I only wanted to express that I have a lot of similar "peculiar" tricks to can solve certain Moho limitations like that one, yes... and I'm a little worried about this kind of changes in the Moho structure/funcionality, so I wonder if really is a good solution eliminate a software limitation eliminating suddenly another stablished feature when users are in the middle of the work... Well, anyway all improvements are always welcomed (of course) and this is only the exception so...
GREETINGS & THANKS!
application/x-vnd.lm_mohodoc
version 14
### Created in Moho version 5.3.1, © 1999-2005 Lost Marble
### Created: Mon Feb 06 16:20:16 2006
### static values
dimensions 1024 576
frame_range 1 56
fps 25
back_color 148 148 148 255
noise_grain 0
allow_3d true
depth_sort false
distance_sort false
depth_of_field false 2 1 0.020833
stereo_separation -1
extra_swf_frame false
soundtrack ""
### styles
### animated values
camera_track
keys 1
0 1 0.1 0.5 0 0 1.7321
camera_zoom
keys 1
0 1 0.1 0.5 1
camera_roll
keys 1
0 1 0.1 0.5 0
camera_pan_tilt
keys 1
0 1 0.1 0.5 0 0
### layers
layer_type 4
### generic layer values
name "Arm"
quality_flags 1022
origin 0 0
parent_bone -2
visible true
render_only false
edit_only false
scale_compensation true
rotate_to_follow false
face_camera false
masking 0
blend_mode 0
camera_immune false
dof_immune false
### transforms
translation
keys 1
0 1 0.1 0.5 0 0 0
scale
keys 1
0 1 0.1 0.5 1 1 1
rotation_x
keys 1
0 1 0.1 0.5 0
rotation_y
keys 1
0 1 0.1 0.5 0
rotation_z
keys 1
0 1 0.1 0.5 0
flip_h
keys 1
0 1 0.1 0.5 false
flip_v
keys 1
0 1 0.1 0.5 false
shear
keys 1
0 1 0.1 0.5 0 0 0
### layer effects
### bone layer values
expanded true
group_mask 0
depth_sort false
distance_sort false
skeleton
binding_mode 1
bones 12
"Bicep" -1 -1 1 -1 1 1 -1 1 false 0.333333 0.25 0 0
false -1.22173 1.22173
keys 1
0 1 0.1 0.5 true
0.5 1 3
keys 1
0 1 0.1 0.5 0 0
keys 9
0 1 0.1 0.5 0
1 8 -1 -1 0
6 7 -1 -1 2.76432
9 1 0.1 0.5 2.733935
14 7 -1 -1 2.733935
18 8 -1 -1 -1.512433
21 1 0.1 0.5 -1.532696
24 1 0.1 0.5 -1.598204
25 1 0.1 0.5 -1.598204
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"ForeArm" 0 -1 1 -1 1 1 -1 1 false 0.333333 0.25 0 0
true -1.570796 1.570796
keys 1
0 1 0.1 0.5 true
0.5 1 3
keys 1
0 1 0.1 0.5 0.333333 0
keys 9
0 1 0.1 0.5 0
1 8 -1 -1 -0.718001
6 7 -1 -1 -1.251573
9 1 0.1 0.5 -0.043991
14 7 -1 -1 -0.043991
18 8 -1 -1 1.672884
21 1 0.1 0.5 -0.382694
24 1 0.1 0.5 0.042253
25 1 0.1 0.5 0.042253
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Hand" 1 -1 1 -1 1 1 -1 1 false 0.111111 0.25 0 0
keys 1
0 1 0.1 0.5 true
0.5 1 3
keys 1
keys 8
0 1 0.1 0.5 0
1 8 -1 -1 0
6 7 -1 -1 -1.051108
9 1 0.1 0.5 0.177229
14 7 -1 -1 0.177229
18 8 -1 -1 1.017384
21 1 0.1 0.5 -0.249336
24 1 0.1 0.5 0.0101
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Bicep Totally Controled" -1 0 1 0 1 1 0 1 false 0.027778 0 0 0
keys 1
0 1 0.1 0.5 false
2 2 1
keys 1
0 1 0.1 0.5 0 0
keys 3
0 1 0.1 0.5 0
1 8 -1 -1 0
14 7 -1 -1 0
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Forearm Totally Controled" 3 1 1 1 1 1 1 1 false 0.027778 0 0 0
keys 1
0 1 0.1 0.5 false
2 2 1
keys 1
keys 3
0 1 0.1 0.5 0
1 8 -1 -1 0
14 7 -1 -1 0
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Hand Totally Controled" 4 2 1 2 1 1 2 1 false 0.027778 0 0 0
keys 1
0 1 0.1 0.5 false
2 2 1
keys 1
keys 3
0 1 0.1 0.5 0
1 8 -1 -1 0
14 7 -1 -1 0
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Bicep Spring Up" 3 1 0.5 -1 1 1 -1 1 true 0.194445 0.5 0 0
true 0 1.570796
keys 1
0 1 0.1 0.5 true
1 0.55 1.25
keys 1
0 1 0.1 0.5 0.055556 0.083333
keys 1
0 1 0.1 0.5 6.283183
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Bicep Spring Down" 3 1 0.5 -1 1 1 -1 1 false 0.194445 0.5 0 0
true -1.570796 0
keys 1
0 1 0.1 0.5 true
1 0.55 1.25
keys 1
0 1 0.1 0.5 0.055556 -0.083333
keys 1
0 1 0.1 0.5 0.000002
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Forearm Spring Up" 4 -1 1 -1 1 1 -1 1 false 0.166667 0.5 0 0
true -0.392699 1.22173
keys 1
0 1 0.1 0.5 true
0.85 0.75 1
keys 1
0 1 0.1 0.5 0.055556 0.055556
keys 1
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Forearm Spring Down" 4 -1 1 -1 1 1 -1 1 false 0.166667 0.5 0 0
true -1.22173 0.392699
keys 1
0 1 0.1 0.5 true
0.85 0.75 1
keys 1
0 1 0.1 0.5 0.055556 -0.055556
keys 1
0 1 0.1 0.5 6.283185
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
"Hand Spring Up" 5 -1 1 -1 1 1 -1 1 false 0.083333 0.5 0 0
true -0.785398 2.094395
keys 1
0 1 0.1 0.5 true
0.75 0.55 1
keys 1
0 1 0.1 0.5 0.027779 0.055556
keys 1
0 1 0.1 0.5 6.28318
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
true -2.094395 0.785398
keys 1
0 1 0.1 0.5 true
0.75 0.55 1
keys 1
0 1 0.1 0.5 0.027779 -0.055556
keys 1
0 1 0.1 0.5 0.000005
keys 1
0 1 0.1 0.5 1
keys 1
0 1 0.1 0.5 false
keys 1
0 1 0.1 0.5 0 0
keys 1
0 1 0.1 0.5 0
### sub-layers
layer_type 1
name "Layer 1"
quality_flags 1022
origin 0 0
parent_bone -1
visible true
render_only false
edit_only false
face_camera false
masking 0
blend_mode 0
camera_immune false
dof_immune false
### transforms
translation
keys 1
0 1 0.1 0.5 0 0 0
scale
keys 1
0 1 0.1 0.5 1 1 1
rotation_x
keys 1
0 1 0.1 0.5 0
rotation_y
keys 1
0 1 0.1 0.5 0
rotation_z
keys 1
0 1 0.1 0.5 0
flip_h
keys 1
0 1 0.1 0.5 false
flip_v
keys 1
0 1 0.1 0.5 false
shear
keys 1
0 1 0.1 0.5 0 0 0
### layer effects
### mesh layer values
noisy_shapes false
noisy_lines false
animated_noise false
noise_amp 0.013889
noise_scale 0.055556
extra_lines 0
gap_filling false
fill_texture ""
line_texture ""
mesh
points 12
keys 1
0 1 0.1 0.5 0 -0.055556
keys 1
0 1 0.1 0.5 -1
-2
true
1
0 3
keys 1
0 1 0.1 0.5 0.194444 0.111111
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 1
keys 1
0 1 0.1 0.5 0.361111 0.055556
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 0
keys 1
0 1 0.1 0.5 0.523025 0.100443
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 12
keys 1
0 1 0.1 0.5 0.666667 0
keys 1
0 1 0.1 0.5 -1
-2
false
2
0 7 0 11
keys 1
0 1 0.1 0.5 0.75 -0.055556
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 10
keys 1
0 1 0.1 0.5 0.75 0.055556
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 8
keys 1
0 1 0.1 0.5 0.505609 -0.086385
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 6
keys 1
0 1 0.1 0.5 0.333333 -0.055556
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 5
keys 1
0 1 0.1 0.5 0.194444 -0.111111
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 4
keys 1
0 1 0.1 0.5 0.805556 0
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 9
keys 1
0 1 0.1 0.5 0 0.055556
keys 1
0 1 0.1 0.5 -1
-2
false
1
0 2
curves 1
13 true
2 true
keys 1
0 1 0.1 0.5 0.3
1 true
keys 1
0 1 0.1 0.5 0.3
11 true
keys 1
0 1 0.1 0.5 0.3
0 true
keys 1
0 1 0.1 0.5 0.3
9 true
keys 1
0 1 0.1 0.5 0.3
8 true
keys 1
0 1 0.1 0.5 0.3
7 true
keys 1
0 1 0.1 0.5 0.3
4 true
keys 1
0 1 0.1 0.5 0.3
6 true
keys 1
0 1 0.1 0.5 0.3
10 true
keys 1
0 1 0.1 0.5 0.3
5 true
keys 1
0 1 0.1 0.5 0.3
4 true
keys 1
0 1 0.1 0.5 0.3
3 true
keys 1
0 1 0.1 0.5 0.3
shapes 1
"1" false true true true
13
0 0
0 1
0 3
0 4
0 5
0 6
0 7
0 8
0 9
0 10
0 11
0 12
0 2
false
keys 1
0 0 0.1 0.5 0.898039 0.701961 0.505882 1
false 0.004167
false
keys 1
0 0 0.1 0.5 0 0 0 1
false
6.283185
0.25
true
-1
-1
-1
groups 0
