Tried the latest version of the freehand drawing tool in Moho 5.3.
I drew a line using a drawing tablet. Had width of line set at min 1, max 12.
Then I used the Line Width tool to reduce the width of the line.
Then I used the Line Width tool to expand the width of the line back to the original size.
The line lost its original width and tapered look. The line width tool made most to the line the same width.
Click to view larger image.
If one uses the line width tool and makes the line width around 0 or 0 then widens the line back up the entire line now has the same width along the length of the line; losing all it´s characteristics of varied widths.
Not really a bug. Think of a photo: First brighten a photo until parts of it turn completely white. Then darken the photo - you won't get the details back in the white areas - they'll all just be a solid shade of gray.
Zero is the minimum line width. When you narrow down multiple points so that they're all at zero, you're forcing them all to be the same width (zero). Then, when you increase the width later, they're all starting at the same point (again, zero).
If you drag the Line Width tool from side to side without letting go of the mouse, the widths don't get clipped like this - the tool remembers the starting line widths. However, once you let go of the mouse button, the new widths get finalized, and some points that didn't used to have the same width might now all have equal widths of zero.
It may not be a bug, but it is bad news for the artist.
I draw my object in Moho with the freehand drawing tool. I have several different lines in the drawing. I want to make them thinner so I have to use the Line Width Tool to change them.
Later I want to change them back or to a different width.
I can´t. The drawing is ruined. I have to start over.
How can the artist adjust the Freehand tool line width in Moho?
And this is not how vector drawings work in other vector programs. Make the lines smaller, make them bigger, the proportions stay the same in other vector drawing programs.
HI! You always can do an Action with the proper line width or save a Keyframe where you want to can copy and paste then to recover the desired point widths... I think that there are several solutions and I agree with LM in his explanation, Moho (thanks God!) treat the line width in a different way than other vector programs and for get that you wish it'd be necessary something like... width memory? I mean, points should remember width factors of the past , or something like this... Seems interesting but complicated, I think that maybe this could not be factible and can be better resolve this kind of problems in the way that I said above or other new ways... CIAO!
Possibly a feature request - reduce the line width to negative values rather than stopping at 0, and just don't draw any width <= 0?
Although it may slow down screen redrawing (and rendering) a bit, since it is adding in an extra test for every point.
Regards, Myles.
-- Groucho Marx
Hmmm, still thinking... yes... could be, so well... I think that if could be possible a definitive auto solution for LM part for users don't worry about it, it'd be nice...but for now, I think the keyframes solution could be a help... hmmm (I think)
myles wrote:Possibly a feature request - reduce the line width to negative values rather than stopping at 0, and just don't draw any width <= 0?
WOW!!! DEFINITELY a very good and SIMPLE possible solution! I think LM could like that (I think ), to my it seems perfect ...THANKS myles for think so well and quick ...BYE!
Unfortunately, line widths less than zero have a special meaning - that no line width is set at that particular point, and it should use the line width of the overall shape instead.
Would you consider using imaginary numbers instead?
line width 3, 2, 1, 0, i, 2i, 3i ...
LM - What´s your recommendation for the artist who draws a character with many freehand tool lines in it, then wants to change the width of the lines within the character?
If one reduces the line too far it loses all it´s characteristics and can´t be widened again.
