Hi,
I seem to be having a problem with my character's thumbnail image when I save my characters in the library.
Instead of the image, I'm getting a color speckled horizontal line. I tried making a new thumbnail with the
same dimensions (203x203) as the others, but that doesn't work. Does anyone know a solution?
AS 11
Thanks
						Squashed thumbnail
Re: Squashed thumbnail
works fine here under windows 7 x64
Have you tried putting a 512X512 image in the library folder?
The image in my insert object panel looks fine.
The thumbnail in the library panel is just a horizontal line with speckle colors.
Anime Studio created the image file for the thumbnail (431x512), which I think is unsual, because their
other thumbnails are 203x203.
I'm also using Windows 7 x64.
I tried saving another file to the library, and the thumbnail looked fine.
I also renamed the layer of the file that I was having a problem with, and saved it to the library,
and it took looks good now. I'm still not sure what the problem was, but if someone else experiences
a bad thumbnail, try to rename the layer before saving it to the library.
The image created in mine is 185X512 px, did some other tests, all came out at least at 512 px in height and with good ratio, maybe a fluke?
Thanks for the info.
I added some more characters to the library, and they all seem to have good thumbnails now.
