Each time I try to export a large scene in AS Pro 9.1, it crashes. I just can't figure out why. And the crash always happens near the end of the process, never at the start.
The .MOV files eventually will be 300-500 MB, so not insanely large. Besides, in AS 5.6 they were exported without any problems.
						AS 9.1 crashes during exporting
Re: AS 9.1 crashes during exporting
First if you're using macpro have a quick look with the monitor for ram and processor usage. Might be a rendering issue working overtime more than the background programmes and the systems throws a panic.  Second might be worth saving in blocks section seeing which is failing or crashing the process.
									A smile is better than a punch even when you want to.
Regards John from Merry England.
MacPro and proud.
MacPro and proud.
If 5.6 can handle these files, then 9.1 can handle them too.
I turned off "Enable multi-threaded rendering", and now they were exported correctly. Obviously that's a bug.
Like all programs the more added the greater the chance a flaw or your system end being out dated. Prime example is Windows all bells and whistles now Mac is following it
 I too had problems with previous AS versions having issues with lack of ram for rendering I had a choice with spending a fortune for over inflated prices for rams or wait for improvements and updates.
MacPro and proud.
MacPro and proud.
Yeah, no.
This bug is still present in AS 9.2.
