Kaleidoscope Effect
jezjones29
Kaleidoscope Effect
Post by jezjones29 »
I've been playing with the new reference layer option to create a kaleidoscope effect. I've shared the file if you want to have a play.
Could come in handy for quick backgrounds.
Re: Kaleidoscope Effect
neat idea!
Little Yamori
Post by Little Yamori »
That was really cool, have no idea how you did that
Yosemite Sam
Post by Yosemite Sam »
Thats an awesome idea!
Jimmy Mills
Some of my Moho Pro work.
this may not be how jezjones did it or even the greatest idea, but this will work in ASP11:
set the drawing options to be peaked points, and no line / no fill
draw a regular hexagon (but any even numbered polygon should work)
make sure there's horizontal line at the top (**not** an apex) [if you use my shape tool this is the default]
position the hexagon to be centred at 0,0 (select all points, select the point move tool and if necessary key in the coordinates)
draw a vector connecting the top left apex and (as above) position the loose end at 0,0
draw a vector from the 0,0 point to the top right apex to make a triangle
(check that you have a peaked point!)
fill the triangle
import your image
set up a group
Group: masking - hide all
image - mask this layer
polygon - add to mask keep invisible
make 5 copies by reference of that group (**not** duplicate layer)
use layer rotate to turn each copy group through 60, 120, 180, 240, 300 respectively
flip horizontally the 60,180,300 group
in the baseline group (i.e. not a copy) animate (move / rotate / whatever) the image layer.
because it's copy by reference all the "cloned" image layers will inherit the motion
sit back and enjoy the show!
Nice!
AS10 (maybe 9.5) had a two steps script for Tiling. First you it created the original tile, so you created the animated content inside (or import it as an image) and then you run the second script to multiply that tile to cover all the output.
In AS11 the script stills there, but instead of duplicating the layer, it create references from it, so you can animate the whole content at once.
The result is not exactly the same than yours, but is very similar for anyone who wants to play quickly :)
Little Yamori
Thanks for the breakdown, I now have a new homework assignment :D
LY
chucky
Post by chucky »
Nice! Great idea Jezz! Combined with the sound scripts could be cool too.
Danimal
Post by Danimal »
It looked good, but that sort of New Age music stole the show!
~Danimal
braj
Post by braj »
This is great, hayasidist it worked great with your steps.
jezjones29
I've managed to create a new tutorial to show how I created the kaleidoscope effect in Anime Studio:
http://www.animestudiotutor.com/link/315/
I've also created a new video to go with it:
