ASP11 How to use Frame by Frame with layers and masking
chucky
Post by chucky »
Hi everyone, here is a longer guide to using Frame by Frame in ASP11 with all the benefits of multiple layers and masking.
Although not immediately obvious, you can very easily keep all the layers synchronised by using a master layer for timing and referencing all the others.
Here is a template that will give you synced layers including blue line, clean-up, fill with masked highlights and shadows.
Many useful styles for FBF are included in the template.
It is fairly in depth and I do waffle on a bit but there are some useful hints in there ( some that I accidentally forget to utilise in the clip itself- keep an eye out for where I tell you that it's often best to use merge shapes and then leave it unchecked for the entire video- well done Chucky).
So be patient and check it out.
Oh and forgive the lousy drawing and animation, I just hope that the method of using the program might be useful and some far better artists will show us what can really be done in this increasingly powerful application.
I'll be happy to answer any questions.
sargumphigaus
Re: ASP11 How to use Frame by Frame with layers and masking
Post by sargumphigaus »
"The video has been removed for being too long" I don't know if that's something on your end or if the system is being dumb.
Draw_Girl
Post by Draw_Girl »
I'm having the same problem with the video too. :(
Droxon
Post by Droxon »
Same issue here...
"Video has been removed for being too long."
Hmm. Shouldn't we be the judge of that? :)
Looking forward to seeing it eventually.
G.
chucky
Post by chucky »
Should be working now , I had to verify as it was so long , but I was asleep :oops: Australian upload speeds are pathetic, we are living in the stone age over here.
If you can't see it ye just sit tight, I'll post again when it's up.
strider2000
Post by strider2000 »
chucky wrote:Should be working now
Hmm, I do see that you just updated it, but it still isn't working for me. Different issue though now. Seems to show a 0 length video. Definitely looking forward to this video :)
chucky
Post by chucky »
It's up
sargumphigaus
wow. I stand totally corrected. Thank you for uploading this. I'll probably watch it 50 more times.
Great video, Chucky. Could probably do without the self-deprecating though (we all know better). :wink:
strider2000
chucky wrote:It's up
Wonderful! Thanks for sharing!
By the way, did you do Crustacea in Anime Studio 10? I was answering another question and realized that when I tried to find a link to it. It's beautiful!
chucky
Post by chucky »
Thanks guys, glad it is helpful. Oh yes I did Crustacea :)
ulrik
Post by ulrik »
Great video, thanks a lot for this!
Chucky, that is a really great tutorial! Good content and captivating. Fantastic. Thanks. I think that answers a lot of the issues that have been raised in other threads. Thanks again.
benecosse
Post by benecosse »
I'm really impressed with the new drawing tool improvements - works perfectly with the frame by frame.
