-Thanks
Exporting just a character?
humanistheart
Hi all, I was wondering is there a way to export just a character from anime studio? For example if I had just an animated head like this
is there a way to just export the animated head without any filler or background in it?
-Thanks
-Thanks
Re: Exporting just a character?
Just switch off visibility of the remaining layers.
humanistheart
Turning off the other layers still leaves a white background, unless I misunderstood what you meant.
That background can be exported transparent if you use a codec which supports alpha. For example, Quicktime PNG Millions of Colors+humanistheart wrote:Turning off the other layers still leaves a white background, unless I misunderstood what you meant.
humanistheart
Thanks so much for the reply! The png did work, however it exported the animation as a series of pictures, any way of exporting it as video?selgin wrote:That background can be exported transparent if you use a codec which supports alpha. For example, Quicktime PNG Millions of Colors+humanistheart wrote:Turning off the other layers still leaves a white background, unless I misunderstood what you meant.
Yes, you exported as PNG files and not as Quicktime PNG file, as I said.humanistheart wrote:Thanks so much for the reply! The png did work, however it exported the animation as a series of pictures, any way of exporting it as video?
In the export window you must select Quicktime Movie. Once you press ok, a new window will be opened with the specific Quicktime options. There you select PNG codec and Millions of colors +.
The exporting result will be a single .mov file, with PNG compression and transparent bakground.
humanistheart
Unfortunately the version I'm using doesn't seam to have a Quicktime Movie option. Thanks for the help though.
You can't export to Quicktime when running at 64bit. To solve that, simply go to File>Relaunch in 32bit modehumanistheart wrote:Unfortunately the version I'm using doesn't seam to have a Quicktime Movie option. Thanks for the help though.
The software will be closed and reopened in 32 bit. In that version you can export to Quicktime.
humanistheart
Oh okay, great... how do I do that?selgin wrote:You can't export to Quicktime when running at 64bit. To solve that, simply go to File>Relaunch in 32bit mode
With Anime Studio open go up to file and then in the drop down select relaunch in 32 bit. If for some reason that is not there its because you did not let it install while installing the program. To fix this reinstall both versions of anime studio.
Gracias por su ayuda Víctor cuando usted me ayudó!
McCoy Buck's YouTube Channel
Published Author | Moho Trainer | Rigger | Animator
"I wrote the book on Moho..."
¡De nada!mtbuck24 wrote:With Anime Studio open go up to file and then in the drop down select relaunch in 32 bit. If for some reason that is not there its because you did not let it install while installing the program. To fix this reinstall both versions of anime studio.
humanistheart
Okay, looks like I finally got it! Thanks so much to everyone that advised here
Seriously, I would not have figured that out on my own!
